Sky InsuranceVolks Autos
Results 1 to 12 of 12
Thread: White smoke
    Sep 2009
    Isle of wight
    207
    White smoke
    I have white smoke combining from my exhaust every now and again, it's quite a lot when it happens, smells as though its running quite rich,could anyone put me in the right direction what this could be
    Sep 2009
    Isle of wight
    207
    Anyone?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    It could be a few things Tony heres a link
    White smoke from exhaust :(
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    White smoke indicates burning water, fuel is usually black, and blue is oil...
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    sorry to say but blue or white is usually pretty bad... if its more blue its prob either turbo seals, valve stem seals, or completely shot piston rings, if its white either head gasket or cracked head block or completely shot/cracked turbo..... think your nrxt step is a compression test, rempove all the spark plugs and insert the tester and wind over two or three times all four readings should be the same at least within 5 to 10 psi of each other.
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Sep 2009
    Isle of wight
    207
    Thanks for all the info everyone, going to get it in the garage this week, still got 3 months guarantee on my turbo, which I got from CR turbo, fingers crossed then
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by Tony gold View Post
    Crossed mate...
    Sep 2009
    Isle of wight
    207
    Car booked in for Friday, got an AGU head sorted just in case
    Sep 2009
    Isle of wight
    207
    Just got my car back and head gasket is fine, got a coolent leak from turbo,they seem to think I may have a blocked breather hose? That's why it could be smoking,you can also smell fumes in the cabin,could this be true?
    Sep 2009
    Isle of wight
    207
    Bump
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    Sep 2009
    Isle of wight
    207
    Pollen filter changed the other week,so will check pipes, any ideas on blocked breather hoses for smoking? Cheers
  1. '00 2.5tdi clouds of white smoke!!!
    By 0v0 in forum Diesel forum
    Last Post: 18th May 2011, 00:34
  2. Puff (cloud) of white smoke on start up..Is this normal
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th March 2007, 15:29
  3. Poor starting / white smoke
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2006, 21:49
  4. White Smoke?
    By vishal in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 13:45
  5. white smoke???
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 02:35
