Volks AutosSky Insurance
    Oct 2011
    723
    brake and clutch problems
    Hello
    Ive had my engine out over the last few days to fix my cracked manni and replace the clutch and flywheel.
    poly bushed the front end while i was at it and fitted some gt brembos.
    After bleeding the system, or so i thought, the pressure bleeder hose inside the bottle had come away.
    Loads of air coming through on passenger corner (last one to bleed).
    So i re bled the system, the mc and clutch.
    Now the pedal travel is all the way to the floor and the clutch will not engage any gears while the car is running.
    There are no leaks anywhere that i can see.
    Any ideas of whats gone wrong?
    Any info much appreciated
    Lewis583's Avatar
    Mar 2010
    833
    Did you bleed the clutch slave cylinder?
    I would bet that you need to do a full bleed of the brake system, Master cylinder/cycle the ABS pump with VCDS/at all calipers.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Oct 2011
    723
    Quote Originally Posted by Lewis583 View Post
    Thank you much appriecated
    No i didnt do the slave cylinder, so much going on that i forgot. I did the whole job on my drive without splitting the box and 4wd on my own, never again its weighs a ton
    I take it you mean cycle the abs pump through vcds at every corner when bleeding?
    Oct 2011
    723
    Hello
    Thanks to lewis above for info about bleeding abs unit it worked.
    But still couldnt get the clutch to engage(even though the clutch pedal worked, not on the floor)
    So went out with the intention of bleeding the slave cylinder.
    Hooked up the ezibleed kit and then fluid just made a river under the drivers door.
    Traced it back from the chasiss leg up to to the black housing where the master cylinder sits.
    I could see where the master cylinder sits on the black cylinder air and fluid escaping from the seal.
    I take it the master cylinder seals have gone?
    Best place to source one from?
  1. Brake and Clutch pedals
    By Legend7 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th December 2011, 11:20
  2. Brake and clutch fluid change help
    By pj123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2011, 12:47
  3. Brakes and clutch
    By Rheady in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th October 2010, 22:18
  4. Clutch and Radio Problems
    By Moose in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2008, 18:23
  5. brakes and clutch upgrade
    By youngdriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2004, 19:17
