Chris NottAH Fabrications
    Bristol
    34
    Creaking / play in front driver side wheel
    Recently, I have noticed a squeak from the front right wheel whenever I go over a bump or the suspension gets compressed. I have been getting the train to work recently so haven't been using it, and have only just had a chance to have a look at it.
    Firstly, the top mounts look different - drivers side sits higher than the passenger side;
    A short video of me jumping on the door sill to show the sqeaking;
    IMG0521 - YouTube
    So I jacked it up today, and there is a LOT of play in the front wheel, I can move it by hand about 2cm (in the direction as if I am turning the steering wheel). The play is the bumper side of the wheel, the door side of the wheel is solid. When I do this the whole suspension strut, brake etc moves, and the top mount turns when I do it also. The car is on KW coilovers and had the lower ball joint replaced just before Christmas.
    Any ideas on what would be causing this would be gratefully received, needless to say I will continue to get the train until this is sorted!
    phil miller's Avatar
    Sep 2012
    Devon
    843
    bottom ball joint is gone i would of thought, that is why you have movement, the top mount bush is worn, thats prob giving you the noise
    ​Wish Rachel would let me have my TDI mk5 back
  1. Rattling noise from front driver side
    By sanj_c in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 23:33
  2. WANTED: front drivers side spring for 2002 S3
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2010, 16:39
  3. Replies: 9
    Last Post: 8th February 2010, 15:49
  4. TDi Alloy intercooler pipe (behind driver side wheel)
    By sprout99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2008, 07:49
  5. knocking on front passenger side wheel
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th November 2006, 15:16
