AH FabricationsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 57
Like Tree7Likes
Thread: s3 road going weight?
    May 2013
    85
    does anyone know the weight of an 8L S3 in full trim (non sunroof)
    im looking to build a stripped out one as a fast road/track car, and im curious as to the starting weight, i think they are about 1500kg, so a touch lighter than a mk4 r32, autotrader info seems to suggest over 1900kg which is rubbish as it will weigh more than my A6 Avant quattro.
    Id like to see if the weight can come down to 1250kg (or lighter?) has anyone got one down to that weight(ish)
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    There about 1450 I think....
    May 2013
    85
    should see 1250 when stripped out then
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    Mine is 1,461kg. Says in the boot.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    May 2013
    85
    excellent, cheers - seems they are about 100kg lighter than mk4 r32 (some of that due to the v6 obviously)
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    i thought somebody on here had recently decided to properly strip their S3 for a track car project - cant remember who it was now
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,062
    around 1450 is the typical weight Jason.
    For reference, my A3 started out at 1250kg, and after stripping everything and fitting light weight wheels and seats, I actually got this down to 1060kg at one point, but since adding back the cage, fire ext system, ARB's, and other weight safety gear It's gone up to around 1140kg (1133 last weigh in before fire ext).
    On that logic, 1250kg should be possible as the S3 has some heavier std equipment than the A3.
    May 2013
    85
    cheers mate, ive read your thread and posted up, only decision i might have to make is to buy an S3 or do another mk2 1.8t20v (with a diff this time)
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    I want someone to do an s3 properly, so please so that
    Vex182 likes this.
    May 2013
    85
    mk2 would be cheaper, god knows what you have laid out on your A3
    May 2013
    85
    so anyway ive bought an S3, whether it makes it to a track car is anyones guess, had a bit of work done to it but the turbo is too big and laggy for my liking.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,108
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by jasongtr View Post
    Welcome
    What's the spec of this S3 you've got? Anything modified at all?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    May 2013
    85
    cheers
    T3 turbo
    Scat Rods
    boost controller
    genesis 550cc injectors
    porsche gt2 brakes with 2 piece discs
    rs4 alloys
    boxed off induction filter
    straight through milltek exhaust
    forge fmic
    probably bits ive missed
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,108
    Well sounds like you have a good starting point judging by the mods.
    Do you have an idea on what it's running and who mapped it?
    Try and get some pics up and create a thread I reckon....especially if your even considering tracking it etc.
    2000 S3 APY
    May 2013
    85
    supposed to be running 350 and did show 420 on the dyno but they backed it off due to fueling, i have a receipt for a very recent dyno session at Storm, who knows if the figures above are true but when the turbo kicks in its fairly quick, just boosts to late for my liking
    stevegti2's Avatar
    May 2011
    223
    the s3 front seats weigh 49kg a pice according to my scales that was the non heated version 1250 should be vry achievable my a3 is 1120kg still has carpet and 2 stock 5 door front seats for now
    the stock s3 alloys are nearly 12kg a pice ! wich is very heavy for a 17x7.5j the 18s on a r32 are oz and a fair bit lighter i havent weighed one but just to pick up theres a noticeable difference
    the s3 has tons of crap it dont need xenons the adjusters on susepension smog pump ac system the interior subwoofer cd changers etc etc the carpet in a A3 S3 is 9 to 10 kgs its really thick high quality stuff so
    BURN RUBBER NOT YOUR SOUL !
    May 2013
    85
    49kg each fappin hell
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Forge intercooler (assuming its the normal S3 one they sell) is way too small for 350+ hp... will be quite a pressure drop on that... it won't help your spool for sure...
    550cc injectors are ok on a 4bar FPR for 400hp though... miltek is 2.75" mostly... 3" is better for 400hp capable engine... if still running the std S3 inlet and small port you will struggle with a reliable 350-400hp... must be running all the boost in the world to see that power unless the turbo is huge...
    <tuffty/>
    May 2013
    85
    no idea on some of that, ill wait until my ramp is free and get it up i the air, whip the bumper off and have a look at the fmic, it certainly looks std inlet so i assume its std small port head too.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,281
    Lol He's challenging you! ;-)
    cheers
    T3 turbo
    Scat Rods
    boost controller
    rs4 alloys
    forge fmic
    To build a track based car, that is exactly what you have to do mate ......start out purpose building it as a track car IMO.
    Think light everything, someone on here recently has stripped an s3 and started track car proceedings , cut his front bumper up for the big front mount to get as much flow as possible ect...think he was going to weigh it and his is stage 2 iirc.
    if/ when I build a track s3 I think I will stick to k04 turbo or hybrid beach buggy k04, a healthy 1200kg fully sorted s3 stage 2 280 bhp will be a good track car. 0-60 of westy's I think is approx 4.6 seconds stage 2 with all the weight in! Stage 2 s3 k04 turbo doesn't have a lot of lag and the power is just there, off the line and mid range, 2nd and 3rd gear gives massive smile as you plant the loud pedal.
    Just some food for thought........
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    May 2013
    85
    sorry but 280hp in 1200kgs is not quick enough, ive just broke an mr2 turbo with 320hp and that weight as it wasnt fast enough, to be honest my plan for buying this car was to rid the laggy turbo have a genuine 350hp running nicely in this car then rip it out and convert an S1 elise with it, so ill then have 350hp and no more than 800kgs in a genuinely excellent chassis
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,281
    quattro will put the power down better than any mr2, genuine 350 should be great dont forget your suspension, brakes, cage, fluids, ect to suit and JBS designs is the place to talk to about Elise vag 1.8 20v t they built a 450 bhp 800 kilo Elise and its for sale on their website or was for £25,000 iirc
    May 2013
    85
    im already on seloc so i know where to get the parts to self build the car, cheers though always helps to have more outlets for things
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,522
    You know, a focus ST (5pot) weight 1437kg!? I thought they were heavier! Turns out the s3 is a lard arse! Lol.
    May 2013
    85
    not as much as a mk4 r32 though
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,108
    Is that a 5 door or 3 door ST out of interest?
    2000 S3 APY
  28. #27
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,281
    I had a 3 door st and it certainly didnt feel heavy......... Bet you could strip one down to 1150 kg ish ???!
  29. #28
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    Quote Originally Posted by Gops View Post
    my mrs' 3 door is sub 1400, im sure of it
  30. #29
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,611
    What about the rest of the car
  31. #30
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    Quote Originally Posted by voorhees View Post
    I thought you were better than this
  32. #31
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    Is this finished yet?
    i need someone to race
    s33nyboy12 likes this.
  33. #32
    May 2013
    85
    if you mean mine, i might well of bought the car for the engine and break the rest, having said that once i sort out the turbo you never know
  34. #33
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,522
    If I get bored with mine prawny then I will :D
  35. #34
    May 2010
    Bedford
    2,877
    Buy Westy a runaround and he`ll be with you lol.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  36. #35
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    cheers
    T3 turbo
    Scat Rods
    boost controller
    rs4 alloys
    forge fmic
    When does the turbo kick in??
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
  37. #36
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,062
    Quote Originally Posted by Paradox1 View Post
    tuesday
  38. #37
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    tuesday
    lol trust you
    Word!!!
  39. #38
    May 2013
    85
    he's not far wrong, according to the boost gauge a little bit happens at 4k, then a fair bit more at 5k - so way too late for my liking. Fine if its always having its neck wrung, but for a a fast road car its not good
  40. #39
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    ebay turbo??? My GT3071r is on full chat before 4k...
    <tuffty/>
  41. #40
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    or a HUUUUGE housing.
    may be just a case of changing to a smaller one.
  1. what is our road tax going on?
    By karl210 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2013, 10:02
  2. Going back on the rolling road....
    By Vex182 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2012, 14:45
  3. Going on a road trip.
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2012, 15:31
  4. a3 sqeaking/creaking when going over road humps
    By codrock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2012, 16:50
  5. Replies: 0
    Last Post: 30th September 2010, 11:40
