Hi guys me and jojo went to chemix last Saturday to get our cars sorted due to my overhaul of the front end and S3dave's rear tie bars, which me and jojo both have fitted recently. I got there half 8 and straight on where my results from first measurement were quite a bit out but better than last years where they couldn't do anything as I had a problem with the front wheel position.
Here's last years result.
Then after the work I had done and with S3Daves tie bars this was how it was before they adjusted it.
Now as they started to adjust things the guy said they couldn't alter the front camber as it was out to far, but luckily I had Joe with me who I must say is very clued up when it comes to cars and handling setups, he showed the guy what to do to alter it as there is quite a decent bit of moment in the ball joint to wishbone fixing point to correct it to almost what we wanted. Virtually everything was adjusted it took quite a while but luckily with Joe being there and giving his input it ended up a great setup.
Here is the final setup, Joe recommended the rear camber to be set at -1 to aid handling, which after a weeks driving it feels very planted and responsive.
I feels great now and well worth the money doing it.
Joe's alignment went very well and a lot quicker as he had less to have adjusted than me and his ended up a great result.
thanks jojo for your help and input.
Cheers, Chris.
Cheers, Chris.
