JMB RetrofitsSky Insurance
Like Tree1Likes
  • 1 Post By JUS3IN
Thread: help refitting turbo today, prime oil feed?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    hey all, do i need to prime the oil feed when i refit my apy s3's turbo today??? if so how?
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    right for others reference ive called bill at badger 5, to prime the oil feed to the turbo...
    *fill pipe as best you can with an oil can
    *once all refitted un plug the injectors and turn over 5-6 times to get the oil flowing
    job done.
    slowcoach3 likes this.
    Aug 2010
    bradford
    1,252
    Hi pal I'd of thought u could do this just by taking injector plugs off and turn over 6 times same thing getting the oil going
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Mar 2013
    Chelmsford , Essex .
    239
    This is the correct way to do it but for the future remember it will generate 4 fault codes !
    just remember this when code reading it as it could lead you up the garden path !
    baz
  1. Turbo oil feed 06B145771N
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th April 2013, 19:19
  2. Oil leak from turbo oil feed. what gasket?
    By marshall-12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2012, 19:16
  3. brand new n75 and dv black silicone + turbo oil feed braided
    By tony696 in forum For Sale/Wanted - Audi Parts
    Last Post: 22nd June 2011, 18:21
  4. Turbo oil feed oil weep
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2009, 20:23
  5. Who said turbo needs Engine Oil?
    By godwine in forum General Chat
    Last Post: 6th November 2005, 00:02
