Monster MotorsportBadger5
    Apr 2013
    New owner - couple of questions (boot handle, boot struts, outside temp gauge)
    I recently joined the Audi club by buying an Audi A3 1.9 TDI 130 in ming blue (moving from a BMW 318Ti Compact). So far I'm very pleased with the car, came with a superb full Audi service history, it's in very nice condition for its age ('53' plate) and while its does not have all the toys of my previous BMW it is a beautifully made car that returns a fair amount of speed and great mpg. I plan to leave the car stock and I'm polishing it up and currently sorting out some minor issues. The first issue is the rear tailgate/boot handle, the right pad works and left pad does not. I imagine its probably the micro switch (had that go on a previous Mini Cooper) is it easy enough to replace just the micro switch or do I need to be looking at a replacing the handle unit? The rear tailgate/boot struts are working but sounds like they are leaking pressure, the black end caps on the cylinders have cracks in them. Any recommendations for suitable replacements? Finally mine is a half DIS model, so very limited amount of info shown to the driver but I don't have the outside temp displayed at all. It would be useful, especially when you live out in the villages and the lanes can be fun in winter. Did all A3 TDI's with half DIS have the outside temp gauge, the owners manual seems to indicate that is true? Do I need to find VCDS owner to sort that out? /where is the temp sensor in the car so I can see if one is fitted? Thanks for the help.
    Apr 2013
    By the way - its amazing what you guys do to your A3 S3 and 1.8T's
    Feb 2011
    Leeds
    176
    Cant help you on the tailgate switches, However boot struts can be picked up cheaply from a breakers.
    My PD130 has half dis and displays nothing whilst driving, I have activated the outside temp gauge to be displayed using VCDS but it then returns an error saying there isnt one installed so may be a case of seeing if your car has the necessary plug.
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    You can just replace the micro switch, can't remember what side mine was that went but I bought 8D0827565D & 8D0827359A (ones the switch one is the seal) I seem to remember each side has a different part number though. edit: BAM 52 S3 btw!
  1. New owner, couple of questions!
    By Pandy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2010, 20:18
  2. New S3 owner - couple of questions
    By Matt2010 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2010, 18:03
  3. New owner has some questions
    By toathus in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2010, 10:07
  4. A4 S4 03 Plate - Possible new owner with modification questions...
    By scoose in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th January 2009, 13:35
  5. New owner - couple of Q's
    By NickRE2000 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2004, 18:50
Tags for this Thread
