Volks AutosBadger5
    May 2013
    Car hessitant/ any idea's
    Hi Im a newbie on here and am in need of some advice iv just bought a 99 reg S3 for the wife after picking up the car we had a long drive home my question is when the car accelarated it would hold back for a few seconds and then it would go ok this happened at all the roundabouts and junctions. Any advice would be helpful.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    best place to start is spark plugs then coil packs, also worth giving it a scan to see if anything is recorded
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Agreed with above. Plugs, coilpack or a boost leak.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Mar 2013
    Chelmsford , Essex .
    235
    Unplug the the N75 valves multi plug and drive under the same conditions , my wife's one did the same when we drove it home , unplugging it takes that valve out if the loop and runs the car at actuator pressure if all runs ok all be it at reduced boost/power you have found the cause
    if not its something else !
    baz
    May 2013
    My son plugged in the vagcom and N75 came up as a possable cause along with boost leak im thinking N75 as i have an S2 and when it had a boost leak it pulled really hard to 3000 rpm then nose dived as if you put on the brakes and kept doing it until normal driving and it was fine again same with my sons S4 so i will start with the n75 first and see what happens.
  1. Any idea's why my car wont start ??
    By 951 in forum General Chat
    Last Post: 7th February 2008, 12:01
  2. Any idea whats wrong with my car ??
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th November 2007, 12:50
  3. a3 leaking water into car ?? any ideas
    By nick1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2007, 12:41
  4. A part has fallen off my car. Any ideas where it is from?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2005, 18:46
  5. Help needed!!!!!!!!! Any idea what country these cars are from?
    Last Post: 15th September 2005, 23:06
