Relentless manifolds proof god hates us ?,
mclean1988
bristol
Been trying to fit my relentless manifold today and been having a right mare!!
After having grinded a spanner to its death I think I have final managed to tighten the 9th bolt !!
I've gone to fit the turbo and see no physical way of getting the turbo bolt through the manifold ??
Has anyone got any tips from previous experience ??
I boy pal that's hard I did it with head off and to me there is no way
did you remove a ferw mm off the top edge of the flange to prevent it fouling the head casting, all of the ones I have seen don't fit without modification
Hi mate
Yes studding the turbo to manifold with the relentless manni is the only way.( mines a v2)
The bolt next to the head you can get away with, the other two you cannot.
You will need to cut a couple of mil of the other two studs to get the nuts on.
I got my studs and nuts from tps.
Buy a couple of extra nuts for the studs, the fall down the back of the engine and are hard to find.
Make sure you bolt the turbo support bracket up or this could happen.
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187191-v2-cracked.html
Good luck
Thanks for the reply , any idea on what size and length stud I need ??
Y
2K
766
12
2K
21
5K
