List of parts for my build
IrishDave
Dublin, Ireland
This is the list I have so far:
Pistons/piston rings
Rods with fasetner's and bearings
550cc high imp injectors
Big bore head gasket
Crank seal front&rear
Main bearings
Head Studs
Turbo
Phelonic intake gasket
Exhaust & turbo gaskets
Sump sealant
Oil pickup pipe
Is there anything else that I am missing that should be on that list
Main bearing bots. I presume are the same as a Main bolt set. I could probably add a new fuel pump or will the standard one be adequite.
In that case, you'll need lots of tissues and a few spare pairs of pants in the car at all times!
703
6
745
11
2K
13
