EM TuningMonster Motorsport
    Steven.c's Avatar
    Auto-Motive Restored Deatail
    Sep 2011
    Shropshire - West mids
    282
    Question Does this log seem right for a 1.8T AUM with a revo stage one??
    Hi, i have a 1.8T AUM engine with the following mods
    Revo stage 1
    Turbo intake pipe
    Jetex cone filter
    n249 bypass
    Catback exhaust.
    I logged the car on the motorway from 3rd gear to 4th which is why the revs drop.
    The peak G/s im getting is 140 g/s from the maf which i would of thought should atleast be in the 170 mark?
    Can anyone see anything wrong with these logs or could it be a faulty maf, vagcom does not come back with any fault codes.
    steve
    Metallic Ming Blue a3 1.8t sport.
    K03s, Revo stage 1, Jetex(JR) filter, Silicone TIP,N249 Bypass, Forge Split-r'seee
    Mk3 GTI Project - < Click me
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    Ive got a AUM (log is in a post somewhere on here) stage 1 map, no catback, panel filter with a mod, n249 delete and 007p and no posh tip and mine worked out at 203bhp using the maf values only difference was I did a 4thgear run from 2000rpm to 6500rpm. Plus I had a boost leak!
    So, no it dosent look right mate if your at 140 g/s that works out at 175bhp (I think) so yeah your down on power.
    Not sure what your prob is but im sure someone will pop along soon
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    Heres the linky to my log, after and before New power run figures!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,055
    Very low airflow
    Lots of timing pull
    Not much load
    Not asking for much boost, and not getting much boost, but actual vs requested look fine. so would suggest another cause.
    For reference, my old st1 AUM used to make around 175-180g/s, boost was around 2400 on the map sensor (1.4 bar) load around 175%, and cf's never more than 1-2
    Steven.c's Avatar
    Sep 2011
    282
    Any idea what could be the problem then? As I have a forge split R which doesn't help but boost has always seemed fine. A log I done awhile ago came back with around 2200 on the boost. The low g/s could that be due to a faulty maf? As my car does smell quite rich sometimes.
  1. does this seem about right? (mapped tqs 0-60)
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2011, 18:05
  2. Does this sound about right? 3.2
    By Nezzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2010, 20:15
  3. Does this quote seem OK?
    By trogen in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2007, 16:08
  4. Replies: 11
    Last Post: 28th June 2006, 22:35
  5. Does this look right?
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2005, 07:30
