Monster MotorsportChris Nott
    May 2013
    Audi a3 1.8t 1996 (AGU) misfire
    Hey , my a3 has developed a misfire on cylinder 3 . It happened when i turned the engine off then turned it back on it was running on 3 cylinders . Its the 1.8t agu engine made in 1999 . Iv swapped coils around and spark plugs . Also checked for broken wires but it still only runs on 3 cylinders have read and wonder if it could be the ignition amplifier? Plugged it onto diagnostics bought up a knock sensor and oxygen sensor - cleared them took it down the road they haven't reappeared ! Iv got to this box ( will add photo now ) is this the amplifier and is there a way to test it? Any help or advice would be appreciated Cheers!
    Mar 2013
    Chelmsford , Essex .
    235
    Hi , your ignition amp is situated on your air box lid with a multi pin plug on each end ( 5 wires in and 4 out )
    so to answer your question , no that isn't the ignition amp .
    As for testing , I'm not sure , I know you can get testers but are pretty dear , not sure a multimeter will be of any help !
    Im sure an anorak will be along soon
    baz
    May 2013
    Its 1999 sorry not 1996 ! Ah i see ! Thanks for your help
  1. audi 100 avant s4 1996 braking problem
    By manji in forum Classic Audi Forum
    Last Post: 6th January 2011, 17:46
  2. Audi a3 1.8 turbo agu 1998 for sale how much ?
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2010, 23:15
  3. Replies: 31
    Last Post: 26th February 2010, 13:14
  4. Audi A3 1.8 turbo AGU forge 007p
    Last Post: 16th February 2010, 22:55
  5. Help please, Audi A3 2000, 1.8t apparently misfireing
    By mobymaster in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2007, 21:34
