JMB RetrofitsBadger5
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Paradox1
Thread: Dropping driver's door
    Mar 2013
    Bridgwater, Somerset
    45
    Over the last couple of months I have noticed the drivers door dropping.
    So when you close the door it does not meet the latch on the door pillar correctly.
    Is it possible to adjust the door hinges in some way ?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    yeah you can adjust it.
    When I swapped my door, I got a jack with a piece of wood to stop it from damaging the door. Loosing the 12 point spline bolts (think they 10mm) and jack up the door until its at the right high. sort of trial and error but thats what worked for me
    good luck
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Might be worth looking closely at the hinge as well....I ended up getting mine replaced as it was fecked.
    With the bolts all tightened up on the hinge and the door wide open - I was able to lift my door up about 1cm! Plus I had to give the door a right good slam for it to shut properly - or guide it in with my hand and lift it up to the latch!
    New hinge + resprayed and it shuts perfect. (I just have a little paint missing from the inside sill above the latch from where it was rubbing previously )
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    JimC64's Avatar
    Apr 2009
    Glasgow UK
    242
    Had a bodyshop do mine, took around 10 mins and gave the guy £10.......all good, a fairly simple adjustment if you know what you're doing
    MY2008 (58) XJ X358 2.7 Tdvi Sovereign LWB remapped to 245bhp, Black, Ivory leather interior with black piping, 20" Alloys
    MY2007 Audi A6 2.0 Tdi SE
    176bhp Stratos Blue, badged as 3.0 Tdi Quattro.Front & Rear park assist,Comms Pack High,Sline grille badge added, 19" RS4 alloys,Rear tints,Dipped bulbs 80W,Mainbeams & Foglights 100W,Number plate LED's,Interior LED's,First Aid Kit,Bootliner,Mudflaps front & rear,Calipers & hubs painted
    Mar 2013
    45
    Cheers guys.
    I dont think I have a 10mm torx bit so, I may opt for the garage to do the job.
    So far nothing is rubbing or dragginng on the road.
    But it has dropped about 5mm
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by Dom Knight View Post
    Cheers guys.
    You'd rather pay a garage probably £60 to do it than buy a torx bit for no more than £1 and do it yourself?
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Cheers guys.
    Its not a torx its a 12 point spline.
    you can get a set off ebay for under £10
    doesnt make sense to pay a garage for a job so simple...
    put it this way, would you call out a kitchen designer to align a sagging coupboard door???
    dre_S3 likes this.
    Word!!!
    Mar 2013
    45
    As yet I have done nothing about the door over the last few weeks.
    I am just figuring out how to access the top hinge bolt with the door open.
    Pretty sure I can do this job but I may have to wait for swmbo to get a spare pair of hands.
    The bottom should be easy enough with an extension bar.
    I am considering removing the wing to falcilatate access.
    I know it's the door that has dropped because when the door is resting on the stricker and not closed the top line of the door does not line up with the rear wing until the door is closed.
    Mar 2013
    45
    I thought that removing the drivers wing would facilitate access the door pillar hinge bolts.
    I managed to undo a few of the wing top bolts but one would not budge and I had to stop trying or damage the bolt.
    Mar 2013
    45
    As we have only had the car about 5 months, I phoned the garage we bought it from and the dealer said he has a m8 who has a body shop.
    So I gave the guy a call and he told me to drop it in this morning early and he would look at it.
    When I got there he had a look, and tolld me to come back in about 15 mins.
    Job's a goodun and the door is sorted.
    I asked how much but the guy said that the garage dealer owes him a pint and the job was a freebie to me.
    May 2008
    68
    Quote Originally Posted by Paradox1 View Post
    I just replaced my door and it was torx bolts... Which rounded off so i had to file flats on to each bolt!
  1. Dropped drivers door, anyone else seen this?
    By GeoffDunk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2013, 22:09
  2. Dropped drivers and passenger side doors
    By A7788 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th September 2012, 21:08
  3. Anyone know how much a drivers internal door handle is?
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th November 2006, 03:04
  4. Does your electric driver's door mirror fold slower?
    By cdb2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th November 2005, 10:25
  5. strange noise when you open the drivers side door
    By MateloT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2004, 13:30
