EM TuningAH Fabrications
    S3 Paul's Avatar
    Oct 2006
    2,759
    Troubles with Brembo GT JNR calipers...
    My 01 plate S3 came with the Brembo upgrade,
    Ive never been overly happy with them but came to terms with how they worked...
    Yesterday as part of the Pre MOT i checked the pads... Jesus ! bugger all left.
    So i called at a local motor factors and just picked up what i could get... Pagid standards
    When i started to remove the pads i noticed the inside pads on both sides of the car were TIGHT,
    I managed to get them out and cleaned up the little bits of what look like spring steel thats screwed to the caliper body and fitted the new pads... the difference is massive !
    can i get replacement shims?
    Is this a common problem?
    Noggy Blue 2001 S3
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    I know my callipers arent jnrs but they are brembo none the less. I had issues when fitting a brand new disc and brand new pads at the same time as they were just too tight. I have to change the disc and the pads at seperate intervals if possible.
    I looked to buy new shims but they weren't that cheap so I just prized of the old ones and bought some high temp glue to fix them to the pads.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,108
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by S3 Paul View Post
    Was there an option to upgrade the brakes to Brembo from factory?
    I always assumed every 8L S3 that was made came with the standard crappy cheese calipers.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,451
    No factory upgrade no
    S3 Paul's Avatar
    Oct 2006
    2,759
    Its not a factory upgrade as such, it was fitted at the Audi dealers from the paperwork that came with the car,
    Noggy Blue 2001 S3
    Jan 2012
    Kilmarnock, Scotland
    292
    What actually happens is the calipers corrode underneat the sliders, forcing the sliders up, and causing the pads to seize.
    You need to remove the sliders (and this is a nightmare to do), clean off the corrosion, and re-fit
  1. ARMREST TROUBLE WITH ASHTRAY
    By CHRISS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2006, 13:01
  2. brembo jaguar xkr calipers
    By raymie in forum Other Brands & Models
    Last Post: 3rd October 2006, 19:20
  3. Replies: 0
    Last Post: 27th June 2006, 10:08
  4. The trouble with friends reuntited....
    By hop2407 in forum Jokes, Games & Humour
    Last Post: 17th June 2006, 06:11
