Sky InsuranceVolks Autos
Like Tree1Likes
  • 1 Post By kwistof
Thread: Brembo Brake pads
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Brembo Brake pads
    Seeing as my s3 wants everything under the sun at the minute, and im to nice to say no, she now wants some brake pads as the warning light has flashed up.
    I'm running standard front brakes, and have seen the pads which I think are cheap.. any body run them?
    FRONT Brembo Brake Pads AUDI A3 (8L1) S3 quattro 03/99 | eBay
    Cheers.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    never used them,
    gues it depends how hard you drive. I use mintex if that helps.
    may be worth changing your fluid while your at it
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,115
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I used to run Brembo's discs and pads on my mk1 punto back in the day!
    I still live to tell the tale and I drove it like I stole it 24/7.....I suppose it also depends on how you'll be using the car?
    You'd expect them to be able to make decent pads and discs considering they are the market leaders when it comes to their calipers.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Ive got ferodo on at the minute, my brakes are sweet tbh, never had a problem with them. Cheers.
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,115
    If you have DS2500 on at the moment, then I personally would definitely try and replace them with the same.
    From what I've read the DS2500 are the best pads out there and so coming from these to Brembo's will mean increased heat fade and braking distances compared to what you're already used to.
    s3clarke likes this.
    2000 S3 APY
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    cheers pal, I think i'll take your advice.
  1. Replies: 23
    Last Post: 8th April 2013, 19:39
  2. S3 with brembo conversion brake pads ???
    By The Squirrel in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2012, 13:18
  3. Brembo brakes and brake pad sensors...
    By imported_MattT in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2011, 07:48
  4. My Brembo 4 pots - brake pad question...
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2010, 17:30
  5. Brake Pad Upgrade?
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 05:19
