Sky InsuranceEM Tuning
Results 1 to 20 of 20
    stevegti2's Avatar
    May 2011
    223
    pistons rods and shells
    hi all about to rebuild a spare engine i have just a couple of questions for the people who have experiance with these blocks
    1. are vw mains and big end bearings good at higher horsepower or should i use acls
    2. wossner pistons alot of slap ? ive never used them but seems to be alot of them out there with P.E.C rods
    any info on parts youve used is appreciated only other engines ive build have used cp pistons and pauter rods but im not a milionaire anymore lol
    thanks
    BURN RUBBER NOT YOUR SOUL !
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,898
    Visit 16Klappe's Instagram Channel
    Why upgrade pistons?
    I quite often say I'm going to do things.
    Then never do them.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    I run OE shells on mine with no issues... calico are the only others I would use...
    If not doing a rebore then stick to OE pistons and fit new rings and hone bores... if going for a rebore then buy JE's...
    <tuffty/>
    Apr 2011
    Dublin, Ireland
    564
    Tuffty. For the main bearing would you use thrust washers or not. To be honest I don't even know what they are.
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Quote Originally Posted by IrishDave View Post
    Erm... think its a given you would use thrust washers... not sure what you are asking?
    <tuffty/>
    stevegti2's Avatar
    May 2011
    223
    pistons because if im doing a job may aswell do it properly hopefully engine will be close to 400bhp near the end of the year plus nice fresh bores more ccs less compression many benifits even if there not needed for the power
    stock shells should work fine then
    tuffty je pistons are the only ones i was trying to avoid they work really well but every engine ive seen with them has slap on start up i know there cheap and cheerful mind
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    Slap just means too big piston-wall clearance. So theyve either bored too big or specd the wrong size pistons.
    Think about it, how can one 81mm piston have slap compared to another 81mm piston in the same bore.
    imo theres no point in pistons unless youre boring out/stroker, or your current ones are damaged.
    You cant go higher comp than you already are anyway so theres another reason not to.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Quote Originally Posted by stevegti2 View Post
    JE's aren't cheap and cheerful mate... no idea where you got that from and as Karl has said, if you get slap then its not been machined right...
    <tuffty/>
    stevegti2's Avatar
    May 2011
    223
    i know why they slap just my experiance with them the machine shop only bores the block to the manufacturers specs ie je cp pistons seem to have a tighter clearance and never slap and are proven in performance from what ive seen the jes expand more than some other pistons
    and im pretty sure that je are one of the cheaper pistons out there ....they work im just not a fan
    karl expansion rates piston shape and material all differ in pistons thats how they differ
    not being able to go higher comp is a reason not too :/?? i want less compression not more and yes i am overboring
    Apr 2011
    Dublin, Ireland
    564
    why could you not raise comp and increase the bore. surely you would not want to lower the comp ratio as this would hinder performance. I plan to run 83mm pistons with a 9.5:1 comp ratio.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Sounds like he really knows what hes doing.
    Leave him to it
    Apr 2011
    Dublin, Ireland
    564
    Actually I was questioning your first comment Karl. Lol. imo theres no point in pistons unless youre boring out/stroker, or your current ones are damaged.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    From what I understand JE's typically use a 2618 alloy which does expand more but but has better tensile strength than 4032 alloy... the specs suggest 0.500" and other sources suggest .004" typical plus .100" if a blown engine due to higher cylinder temps....
    4032 is a harder material so will use tighter tolerances... the 'alledged' flip side is they are less tolerant to detonation etc but in reality still a better material than most OE pistons...
    Not done loads of reading up on this yet as I an currently not in the market for pistons but for most street level tunes you could argue a piston made from 4032 is more suitable but for a track/strip orientated build then 2618 based pistons would be a better choice...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    his current pistons are 9.5:1, im not aware of any 10s out there. But sounds like hes lowering it anyway for some unknown reason. Good luck to him
    Sounds to me like hes read far too much on vortex. Where people have 800+hp drag cars runninh 67mm inducer turbos and piston material might matter.
    Apr 2011
    Dublin, Ireland
    564
    ^^ Got ye. As my current comp is 9.0:1 I will defo be raising it. It does seem rather foolish to lower it unless running big power from an equally big turbo.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Ive raised mine to 9.5. So has tuffty.
    I think lower comp only really applies to BIG boosting high power cars. Im talking 3 bar+ drag cars.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    Not when bored to correct clearance.
    JE not cheap and chearful.. Wossner etc.... they are cheaper
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    www.badger5.co.uk
    May 2004
    nr Glos
    6,935
    mines 9.5:1 CR on badgerwagen now
    previously 8.5:1 CR
    bill@badger5.co.uk
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    No slap on my Wossners @ 9,25:1
    stevegti2's Avatar
    May 2011
    223
    hit the nail on the head with that descrption tuffty thanks i never said there a bad piston they all perform well ive just noticed they slap a bit from cold start up in my experiance
    thankyou bill i was told wossners were alright ive seen a few engines with them none with that much power mind
    i idealy wanted a 9.0-1 cr i like a bit of lee way 9.5 would be better for sure but its only gonna be run on pump fuel its not a all out race car
  1. Track rod and update.
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2013, 20:45
  2. Typical parts associated with upgrade to stronger rods and pistons
    By Neru in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2012, 01:07
  3. APU Rods and pistons into an ARY
    By pippo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2011, 16:03
  4. RODS and PISTONS
    By v5 tt in forum TT/TT-S/TT-RS Forum
    Last Post: 21st September 2011, 19:55
  5. Tie rods and ends.
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2009, 23:12
