Sky InsuranceAH Fabrications
Results 1 to 26 of 26
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    v2 relentless manifold reliability?
    hey all just got one of these v2's, it looks good but since ordering it ive heard bad things... do they all crack? or just a minor few? really want to fit this but having some doubts...
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    heres a link to some pics of mine on my other thread...
    17963 maximum boost exceeded? intermitent boost problem??
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Have an experienced welder go over it and it might be ok.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Based on reported experiences cracking is inevitable especially as the walls are thin and the welds have no filler...
    Shame...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Bill has welded a couple of these now... send it along with your hotside...
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    just checked some pics and mine looks more v3 than v2 and i got all the extra bits welded on!??? maybe mines a cross over one sort of in between???
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    <tuffty/>
    already sent the hotside, will it be reliable if bill works his magic? what would he charge roughly.... also though seriously check those pics of mine it looks like a v3!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Looks like a v3 to me too...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    ...and don't use the supplied copper ****e gaskets... use OE... and replace all gaskets and coolant/oil feed sealing washers too... with OE... they cost pennies but will save you pain...
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    was bought as a v2!!! and what about those extra bits around the 4 into 1 bit, maybe this is a v2 to v3 prototype? hopefully in v3 material?-) welds look v3 aswell right? 239 quid on ebay!
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    got a gasket kit of ebay, guessing this is no good then?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Its a V3 dude... welds use filler rod and not fusion welded like V2... the bracing is an attempt to prevent expansion cracks... material is thicker...
    Stands a chance... make sure you refit the turbo support bracket
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Quote Originally Posted by justarn View Post
    Link would help...
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    im soooo happy tuffty man... what a result!-)
    heres the gasket link
    Audi S3 TT Seat Leon Cupra 1.8T 210hp 225hp 240hp Turbocharger Gasket Kit | eBay
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Hummm... they are better than most but... I would personally only use OE ones... the oil drain (paper gasket in pic) will be next to use less considering how hot turbo's get... the DP and turbo/mani gasket might work... the copper seals may be ok but OE are an aluminium alloy... have seen copper ones corrode from the heat... looks like that kit is missing the oil drain/sump gasket... assuming you have removed the oil drain from the sump
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    not yet but i will be, got an oil filter, oil and coolant on the way, also ebay... missus logged her nectar card to my account so she's lovin it atm!
    lastly darren said he fits his by dropping the gearbox!? ive also got to fit the downpipe... should i just drop the whole subframe off or is there ways around it?
    RIP S3dave
    May 2004
    nr Glos
    7,126
    your turbo
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,126
    now looks like this
    and sleeve welded also as it was loose and jamming wg penny
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,126
    your turbo
    to this
    bill@badger5.co.uk
    Sep 2010
    Devon
    756
    Apart from makink it shiny, why was this done Bill? Sorry if i'm being thick....
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Small wastegate hole = boost creep... all chinese hotsides seem to suffer from it... can't maintain actuator or std boost pressures... worst I have seen crept to over 20psi (on actuator pressure which started at 7psi)
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,316
    very nice work as always Bill
    Sep 2010
    Devon
    756
    All makes sense now, didn't realise its a copy hotside. I'll put myself on the naughty step for skim reading Nice work
    RIP S3dave
    May 2004
    nr Glos
    7,126
    Quote Originally Posted by slowcoach3 View Post
    bill@badger5.co.uk
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    cheers bill, looking good that hole was tiny! did you manage to get her sent?
    and yeah tuffty, mine was creeping to 1.5 bar/21psi! before it was mapped it mustta been a nightmare as the turbo's been on there since 2011 and the map this year... car was stood in a industrial estate in a car mechanics garage carpark for a while... im thinking who ever payed to fit the chinese turbo was so fooked of with it he just parked her up! last owner bought it and attempted stuff, then she's come to me... fingers crossed all will be well!-)
    RIP S3dave
    May 2004
    nr Glos
    7,126
    as I said, Its leaving Tomorrow. should arrive you friday
    bill@badger5.co.uk
  1. Fitted Relentless Manifold
    By IrishDave in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2012, 21:54
  2. What's involved in fitting the Relentless manifold?
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2012, 21:17
  3. Exhaust Questions - Relentless Manifold/De-Cat Noise?
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2012, 17:52
  4. Anyone had problems with XS/Relentless Manifold?
    Last Post: 10th April 2012, 15:35
