Chris NottBadger5
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    on and off red oil can?
    Hi guys seem to be having endless problems with my oil pressure it had a blocked pick up a few months back and recently after deleting the PVC I randomly get the red oil can (has happened twice) but when I turn off the ignition and back on it goes I also sent it to the garage to get the pressure checked and they said its fine?
    What could it be it scares the c%&p out of me when it comes on
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    could be the sensor
    Dec 2012
    Manchester
    44
    I had the same issue on my old a3 when I first did the pcv delete. Turned out I didn't block the brake boost pipe up properly.
    Once I sealed that up correctly the oil pressure light never came back on again.
    Nov 2012
    Kent
    459
    hmm you see i had trouble with the brake booster as i have an aum so i had 2 nipples under the inlet and the piping was different to the guide so i just left it attached could this be it?
    Dec 2012
    Manchester
    44
    To be honest I have no idea haha. I just stood there and watched my mate sort mine at his garage.
    sorry I couldn't help.
    AVLO's Avatar
    Mar 2012
    Doncaster
    277
    do you get any tapping in the time the light is on? i wouldnt like to be the bearer of bad new but could it possibly be a oil pump problem? i only ever had the red oil light flash up once and it was the pump that stopped
    BRING ON THE WET WEATHER ​QUATTRO FTW
  1. Red oil can warning on my 'new' S3
    By DaVinche14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2013, 10:47
  2. Relays, red oil can, crazy beeping, HELP!!
    By Sean's AGU in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2013, 17:15
  3. Red oil can of doom!
    By Chriscooke in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2012, 18:27
  4. Boost shutting on and off under slow acceleration??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2007, 06:54
  5. The Wolf and Little Red...
    By rraghvani in forum Jokes, Games & Humour
    Last Post: 23rd November 2006, 22:49
