Sorry dude... all that is meaningless...
you need to log block 115 at least to see what boost is doing... some info on your car (year, engine code, any mods etc) would help...
Basic loging info is in the FAQ's in the stickies...
<tuffty/>
hi thanks for reply, sorry its a 1999 audi s3 210bhp and think its amk engine code, will i need to be driving the car when i log block 115 ? is there any other blocks i should be loging to check for boost leak? ive check block 032 and short term was -0.2 and long term was 1.6, i reset fault codes and the both returned to 0.0, thanks again Monday,29,April,2013,15:25:11:10462
VCDS Version: Release 11.11.5
Data version: 20121222
Address 01: Engine ()
15:23:57 Group 032: Lambda Control (Mixture Adaptation)
-0.2 % Adaptation (Idle) Bank 1 Sensor 1
1.6 % Adaptation (Partial) Bank 1 Sensor 1
Bin. Bits
Bin. Bits
Monday,29,April,2013,15:28:28:10462
Address 01: Engine (8N0 906 018 )
15:28:19 Group 032: Lambda Control (Mixture Adaptation)
Bin. Bits
Bin. Bits
Monday,29,April,2013,15:41:45:10462
15:41:37 Group 001: General
840 /min Engine Speed (G28)
87.0°C Coolant Temperature (G62)
1.6 % Lambda Control Bank 1
11111111 Basic Setting Requirements
15:41:37 Group 031: Lambda Control (Lambda Sensor Voltages)
0.545 V Lambda Control Bank 1 (actual)
Bin. Bits
Bin. Bits
Bin. Bits
15:41:37 Group 032: Lambda Control (Mixture Adaptation)
0.0 % Adaptation (Idle) Bank 1 Sensor 1
0.0 % Adaptation (Partial) Bank 1 Sensor 1
Bin. Bits
Bin. Bits
