Thread: Rod bearings
    Apr 2011
    Dublin, Ireland
    619
    Rod bearings
    What do you suggest? Oversized rod bearings or standard.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Why would you use over size? only need that if the crank has been reground... stick to std size bearings if doing a straight swap..
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,162
    if you mean additional clearance ones, eg +0.001" then I would only use these on big power 450-500bhp+ applications.. where you might want to run a smidge more clearance.. Badgerwage runs +0.001" for example, but I dont use them on normal bt builds.. sub these power levels.
    as opposed oversize which is as tufftys says a regrind type thing re crank etc.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Apr 2011
    Dublin, Ireland
    619
    Should have been clearer. Additional clearance is what I meant. Thanks for the info.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Additonal only on high power free revving race engines IMHO
  1. Recommend main and rod bearings?
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2013, 10:06
  2. Replies: 1
    Last Post: 21st January 2013, 18:22
  3. ACL / Calico rod bearings.
    By g60leigh in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2012, 17:36
  4. Replies: 5
    Last Post: 30th October 2003, 03:20
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
