Chris NottSky Insurance
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By JudderMan
Thread: Ko3/k03s conversion agu engine
    Apr 2013
    Warwickshire
    32
    So today I started to strip my audi 1.8t sport , I brought the car with the turbo gone literally plumes off smoke out the exhaust , so I gav it a rev an u could tell the turbo wasn't spoiling up , so anyway I bought it got it brought bk on a recovery truck an when we got bk there was an oil trail from the exhaust were the back box joins to the centre pipe , we got the car off the truck but it was late so I pushed it on the driveway an tht was that , the next day I went out in the morning an all out the end of the back box an the join there was oil all over the drive lol , I took the intercooler off ( standard one ) an it was full off oil when I took the pipe of the top it jus pissed oil everywhere oil again , roughly about 1.5 litres if not more , cleaned it all out , an then refitted it , toolkit the exhaust off so I can now replace the turbo an that's full of oil to , plus I can't get my back box off , I carried on removed my coolant , turbo mount, an oil feeds , before u kno it the turbos of, an I didn't get it out a little research an people are saying it goes down ( thou the exhaust channel ) an up thou were the manifold , so I tried both I couldn't get it down so I removed the manifold an then brought it up , I'm about to order the turbo k03s an gaskets an ill repost when it's arrived etc , but it's a pretty straight forward job jus common since , image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgMy friend came round an also pointed out to me my forge splitter had been put on the wrong pipes an that's probably wats cause my TURBS to go, I got some centre caps for my wheels an the didn't fit I had to chop the centre out of them to make hem fit in properly , image.jpgimage.jpgimage.jpgimage.jpgimage.jpg
    Dec 2011
    149
    what the fck happened to that inlet blade lol
    Apr 2013
    Warwickshire
    32
    To me it seems that the bolt came undone an it was flying around near the blades , the shaft the bolt holds is loose as well lol it's fuked properly lol
    Apr 2013
    Warwickshire
    32
    image.jpgDoes anyone kno what that codes for lol
    Dec 2011
    149
    Quote Originally Posted by Chris_38 View Post
    that bolt was there when you took the picture !!! , no wonder its flooked lol . wonder where the bolt came from ??
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    448
    It could have been reconditioned previously
    Dec 2011
    149
    ah , right , the bolt was holding the compressor wheel on , Friday build then lol
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    Wow that turbo is f**ked. On the other hand your socks are a ray of sunshine
    coatesy likes this.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel|Stage1Map
    WANTED: Audi A4 B7 or MK5 5Dr Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Apr 2013
    Warwickshire
    32
    Quote Originally Posted by jimmcgee View Post
    Ye I removed the turbo an cud see the shaft moving so I took the casing off an there it was , it mad I think A3 - lee right because if it jus came undone it should of happend 1000's of miles ago its not snapped either but f*** kno I bought it pretty cheap so I dnt mind buyin a turbo ( an there no point putting a standard one bk on )
    Apr 2013
    Warwickshire
    32
    So she's done an lowered as well
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Did you need marriage counselling with all that mess on the drive..
    Glad youve got it sorted, and looks well...
    Apr 2013
    Warwickshire
    32
    Ahahhaa nah the misses is the best if I pass her something that's Spose to be shiny shell polish it etc , she loves gettin involved this ones for her I rekon if I was to have one I'd put k04 an injectors etc , I'm going to decat this an front mount it remap an leave it like that the only thing I get moaned of is the neighbour lol cuz the exhausts full of oil it's smoking still lol
  1. 1.8t agu engine k03 mpg
    By joebickerton89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2012, 21:27
  2. fitting ko3 or ko3s to standard 1.8 agu engine
    By joe1992 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2012, 21:24
  3. AGU engine into A4?
    By macca in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2006, 13:20
  4. Replies: 1
    Last Post: 1st December 2005, 17:39
  5. diagnostic port on agu engine
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2004, 21:47
