EM TuningAH Fabrications
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By superkarl
Thread: Intake Air Tempature reading too high - MAF?
    Nov 2012
    83
    Hi,
    My S3 hasn't been running as it should so took it a local garage where we ran some test.
    Smoke test showed no boost leaks
    However when reading engine statistics it showed the air intake temperature as 58c. As much as i wished it was that warm it clearly isn't.
    Does the S3 have a separate air intake sensor or is it part of the MAF?
    Any one else experienced this?
    Dan
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    its by throttle body on 1.8t
    stood after being run heatsoak like this would give those temps static.. drops when you drive/rev it and airflow passes by sensor
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    IAT sensor is on the inlet manifold just past the throttle body... FMIC needed really to get the temps sensible as the SMICs are a little stretched especially if your car mapped..
    <tuffty/>
    Nov 2012
    83
    Thanks guys, my cars not mapped.
    It wasn't sat for very long and didn't change when revved.
    Would you recommend changing that sensor then?
    Does anyone have a image of where it is located?
    Dan
    Nov 2012
    83
    Would the IAT sensor log a fault? I have no fault codes.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    You need to record temps on a WOT pull. Stationary means absolutely nothing.
    Standard intercoolers arent very good. Not to mention heatsoak through components.
    Unless yiure seeing 50+ on a WOT run, dont worry
    danderton likes this.
    Nov 2012
    83
    Ok. Looking at the symptoms of IAT Sensor thou - struggling to start, and less power than normal, (poorer than normal mpg) does seem plausible.
    Unless any other suggestions?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,941
    Quote Originally Posted by danderton View Post
    Dan
    is mani hot to touch?
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Never seen an IAT sensor go wrong unless its a wiring issue (not the sensor) or some ham fisted pillock had twated it somehow...
    IAT sensor (if non functional) will give a -48 deg reading in VCDS and will throw fault codes of some description... that said its not always the sensor and more likely the wiring...
    58 deg on idle assuming the engine up to temp and has been driven for a while is not unusal its the recovery back to sensible figures thats the tell... this can only be achieved by getting air though the SMICs so you will need to drive... if its that hot on idle then you won't recover it unless you drive the car as heat soak from the engine will just keep temps up..
    Struggling to start and down on power could be lots of things... airleaks being the prime candidates... smoke test would be advisable...
    the IAT sensor is just one that the ECU uses... if the temps are 58deg then you have to ask why rather than blame the sensor...
    Logging the car in VCDS under WOT should give an indication of where things are...
    <tuffty/>
    Nov 2012
    83
    <tuffty/>
    Cheers Tuffy.
    I had it smoke test this morning too and found no issue. I will try getting a WOT rest and see what happens.
    Thanks Guys
  1. 130tdi fuel gauge reading too high
    By woofdog in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2013, 19:31
  2. MAF readings too low?
    By goldy1234 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2013, 09:03
  3. high fuel consumption (act maf readings too high)
    By navicx in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd September 2012, 17:40
  4. Heater blowing cold and temperature gauge reading too high
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 15:06
  5. A3 1999 air con presure too high
    By daveeeeee in forum Air Conditioning
    Last Post: 7th July 2009, 10:56
Tags for this Thread
