Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    May 2012
    27
    Boost leak test, DV leaking???
    Having some running issues with my car at the moment, first boost leak test i did showed no leaks. I tested from the maf right through. Today i thought i would try a test from the turbo outlet hose to the TB. I removed my DV from the tip. I have two DV's a forge and a bailey. With the forge one fitted soon as i pressuried to 5psi air started to leak from the other side of the valve. With the bailey valve fitted it managed to hold 10psi before starting to leak. I guess this isnt normal? Surely it will be unmetered air?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Theres a thread 2 down from this one that will tell you what to do mate
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    May 2012
    27
    Quote Originally Posted by Paradox1 View Post
    Didnt see that, very good post! what sort of issues would the leaking valve cause?
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    unmetered air issues
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Loss of boost and therefore power..
    <tuffty/>
    May 2012
    27
    <tuffty/>
    Just been thinking, i didnt have any pressure applied to the small vac line on the top. Does this pressure normally keep the valve closed?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Quote Originally Posted by kirkmiles View Post
    Yes...
    <tuffty/>
    May 2012
    27
    Yes...
    <tuffty/>
    Damn, thought id cracked it. Need to do some logs this weekend. can i do any logs to see if its fuel starvation? Ive changed loads of stuff, N75, MAF, coils, Plugs, all silicone hoses, AGU pancake pipe hose, injector seats,inlet manni gasket, cleaned TB. Now im lost :-( Only things i can think of are cracked exhaust manni or fuel starvation. Engine tone drops/changes when i get the problem.
  1. Has anyone performed a boost leak test on a 2.0t fsi before.
    By slim boi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd February 2014, 16:26
  2. Issue boost leak testing AMK
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2011, 11:15
  3. Boost leak test
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2010, 21:17
  4. Help boost leak test
    By Darrenspain in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2010, 06:38
  5. Boost leak test???????
    By malcolm30029085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2010, 13:29
