Badger5Sky Insurance
    Apr 2013
    Bristol
    Fuel gauge over reading by 1/2 a tank
    I have an A3 1.9tdi that over reads by 1/2 a tank. Bizarrely when you get just below the half a tank mark on the display, the fuel light comes on and it's time to refuel.
    So, having read lots of posts and comments I replaced the fuel pump and fuel sender unit and still no luck. I haven't owned the vehicle long and it's alway had this problem. I re-aligned the arrows on the pump with where the old was aligned.
    I am out of ideals now. Any suggestions?
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    Fuel sender doesn't look happy.. Probably worth having a look at it or changing it. It's inbuilt to the fuel pump.
    Mar 2013
    52
    Ive got the same problem on my 1.9TDI. Didnt even realise until i ran out of fuel!
    Ive been told that the speedo cluster is misconfigured and needs to be reconfigured. I plan to upgrade to a full display so im leaving it as is for now. Hopefully a new cluster with full display will sort it out.
    But for you im not sure if you can get is reconfigured via vagcom? im sure someone will know and set us both straight! Good luck with the new motor!
  1. Fuel Gauge NEVER Reading Full
    By A4_MaJiK in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th September 2012, 21:29
  2. 2006 A6 Fuel gauge reading empty.... (2.7 tdi)
    By A6Ian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th May 2010, 10:39
  3. Had a flat battery now fuel gauge reads empty.
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2009, 19:34
  4. Fuel gauge and computer giving wrong reading, help!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2009, 23:33
  5. temperature gauge over reading?
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2005, 16:45
