Chris NottAH Fabrications
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    best way to poly bush..
    I recently acquired a set of poly bushes, for the front wishbones and the trailing arms. has anybody fitted the big bush without a press? I was thinking all thread and washers to push/pull it through...
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Big bush as in the trailing arm? That will drill out no problem, and the poly one will press in when its greased up.
    Same with front wishbones, they drill or burn out. Although the front wishbone rear bush needs pressing in
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    Sorry mate, I ment the big bush on the wishbone. I thought maybe I could pikey it in like I said.. I might just take them off then and pass them onto somebody with a press. Cheers.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Quote Originally Posted by s3clarke View Post
    A poly would go in more easily but OE bushes (especially the TT solid ones) take more effort as they crush in... Prawn has used a vice to get his super pro bushes in...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Yeh you'l deffo need a vice at least with the front wishbone rear bush.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    I think in gonna give it a go with a vice
  1. Best deals on Poly Bushes?
    By StevoS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2010, 16:37
  2. new S3 need to put private registration on - best way??
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2007, 10:42
  3. Cleaning under the bonnet - best way?
    By VAGMAN1 in forum Detailing
    Last Post: 26th November 2006, 22:18
  4. Best way to remove stuck on number plates?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2006, 19:16
  5. Best way to cut back of glovebox to fit Phatnoise?
    By Roswell in forum In-Car Entertainment
    Last Post: 9th November 2005, 18:52
