Badger5Volks Autos
Results 1 to 8 of 8
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Poly bush questions
    Hi guys just a couple of questions regarding poly bushes, first one is can you get poly ball joints? As mine seem to keep going funny, secondly what does the steering Rack bush do? Is it worth changing to the poly bush?
    thanks simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    A bush is a bush and a ball joint is a ball joint... two very different things so no...
    Personally I don't think it is worth the agro of changing unless you have removed the subframe for a n other reason and just feel the need... the rack is positively located into the subframe anyway on the opposite side as there is only one bush...
    <tuffty/>
    Lewis583's Avatar
    Mar 2010
    870
    The steering rack polybush will sharpen up the steering "feel" a touch. I doubt you will feel a big difference though by doing just the rack bush on it's own.
    Never heard of poly ball joints. Describe "funny". I see you are running coilovers, is the car very low?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jun 2012
    Redhill Surrey
    635
    Tuffty I may change the steering rack bush as it may need a new rack anyways, which I will find out next week.
    Lewis, I had h&r lowering springs before coilover which I be leave where around a 40mm drop no driveshaft rub anyways, I changed a lot of parts on the front a put delphi ball joints and track rod ends on about 4-5 weeks ago since then I replaced the ball joints as they had excessive play, but now I get a loose feeling when driving like the car is swaying from side to side slightly, I was going to replace the ball joints again but was wondering if there was a better make than the delphi ones I put on. I have poly bushed wishbones by the
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    Have you checked the bushes in the arms? poly bush those... ball joints are solid joints with no give... if they have play in them they will knock...
    Vagueness can be attributed to worm bushes in the arms... the A3's come with voided bushes in the rear of the arm and these fall apart... you can replace them with the TT non voided versions...
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    My arms are now poly bushes on the front and the rear, if I go lock to lock I get a knock from time to time, may jack the car up later if it drys and see if there is play in the wheel
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Iv done the steering rack bush not driven it yet but will report back when i have.
    chris
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    <tuffty/>
    It's weird how the MK4 has the bush. The MK5 & 6 run a solid mount as I've fitted. No increased NVH but better steering feel since fitting that and other parts. Can't attribute it directly to that as I fitted a fair few other bits at the same time. In fact the car feels better afterwards.
    Tyrolsport offer the solid mount:
    Seems really strange to hard mount one end of the rack and bush the other, it's like the subframe being half solid mounted. I guess it's to give it that "plush" Audi feeling of no connection.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Replies: 63
    Last Post: 28th February 2013, 22:28
  2. Poly bushes for B7 A4???
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th April 2011, 12:20
  3. Bushes question
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2010, 14:02
  4. Best deals on Poly Bushes?
    By StevoS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2010, 16:37
  5. Dog bone bushes question
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2004, 17:09
