Hello dear members I trying to retrofit recaro seats. Below we have diagram how I am planning to do it - basically I will run double core wire from power distribution relay under steering wheel to centre console and then I will split that cable into two feeds for both seats. I will use 25 amp cable and 20 amp fuse in line. Will that work? Also what is that little plug with two brown cables under the seat what is that for is it for memory? Thanks for help ta Si
