EM TuningChris Nott
Results 1 to 9 of 9
    Mar 2013
    27
    Headlight adjuster screw/cog
    Hi people looking under the bonnet of my s3 today and noticed one of my headlights is missing the screw and cog that adjusts it so I thought I can just buy them from Audi but looking at the etka online on the web and it looks like you cannot buy them on there own can someone please help me or point me in the right direction
    thanks
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    I had this problem too, the garage who did my MOT managed to stick a nut on the adjuster.
    Audi will want to replace the whole headlight if you let them touch it.
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    I assume you're left with this
    Cos this has fallen off?
    It's a bummer.
    There is a thread somewhere on here where someone mentions where you can purchase this type of bevelled cog from. I think it was HPC Gears Home page I was going to send them a sample one and they'd make one that would fit.
    Unfortunately without this cog the head lights flap up and down when you go over a bump and you cannot (obviously) adjust the lights.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Jul 2006
    Crewe
    92
    Pull it out as far as possible and put a thick zip tie round it...
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Aren't you supposed to calibrate the lights in VCDS and not really touch those? I just re-calibrated mine after sorting the front and rear sensors and it's miles better.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Sam_ View Post
    No, VCDS calibrates the motorised level adjusters. That puts the motors in theirs default home or middle position.
    you then use the manual adjusters to aim the lights where they should be pointing.
    the motors merely move both lights up or down a bit to compensate for the loads in your cars, Thats why you have sensors on the front and rear wheel. So that the car knows if there's more weight in the front or back.
    liam
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Ah ok. It is also possible to change the home/default position in VCDS too, if needed.
    rhys1210's Avatar
    Oct 2011
    Fareham
    147
    I had the cog missing on mine. i just went to a scrap yard pull one off of a car and fitted it to mine.
    2003 S3 BAM 225 Dolphin grey, Silk Nappa Leather, Bose, Cruise control.
    Mods; custom code stage 1, S3 8P gear knob, pipercross panel filter, APR diverter valve, Forge TIP, Powerflex bushes, R32 rear anti roll bar, spacers F 15mm R 20mm, haldex race controller, Bilstein b12 pro kit, Porsche 996 turbo brakes.
  1. Headlight adjustment with VAGCOM
    By Jamesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2007, 20:38
  2. Xenon headlight adjustment - how much to pay?
    By monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2006, 17:00
  3. Headlights adjustment or diffusion sticker in UK?
    By synthdood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2005, 13:47
  4. Headlight adjustment
    By Jonc in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2004, 14:10
  5. Headlight adjustment
    By kgough in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th July 2004, 20:03
