Badger5Chris Nott
Page 6 of 7 FirstFirst 1234567 LastLast
Results 201 to 240 of 278
Like Tree56Likes
Thread: Tim's Max Power A3
  1. #201
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    just had a crack at my dogbone again but couldnt get the last bold off even snapped a spanner so its not budging sorted the 5th gear problem tho the metal block thing (not sure what it is) was hitting the underneath of the catch can so have raised it up and all good
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
  3. #202
    Nov 2012
    Kent
    459
    Spent another day not training and car instead (falling back into bad habbits)
    finally finished the wrap to a degree that im now happy with, im more than likely going to go all black at some point maybe around winter/next summer time but for now i love the new look, i do still have to sort my tints out but they don't bother me that much atm.
    kwistof and westcoast a3 like this.
  4. #203
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Looks so much better now all the shades of orange match.
    Completely different from how it looked on page 1. Give yourself a big pat on the back - you should be proud you did that all yourself mate and for the first time! Wana see this in the metal/wrap now
    Tim_Attard likes this.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  5. #204
    B7_FUR's Avatar
    Avantee
    Jan 2013
    Worcestershire
    346
    Looking good fella....
    A4 Avant B7
    LED Rear Lights - Mesh Grill - SLC Splittler - Ice White Fogs - Tints - Devil Eyes - Ambient lighting - LED interior
  6. #205
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    How was the sai pump to remove? You leave the bracket in place?
  7. #206
    Nov 2012
    Kent
    459
    Cheers guys, sai was alot easier than it look tbh, yeah i left the bracket there as it was gonna be hassle to get it off and used it to cable tie the resistor/cables too however im not 100% i have done it right as there is a few hoses i have that went into it that i now have left and capped off for now
  8. #207
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Epic thread lol
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
  9. #208
    Nov 2012
    Kent
    459
    Update time, after having a map etc i need to get a FMIC and was the last engine mod on my list, i was going to go the welly cooler route with my own piping as i though it would give me better results and probably easier to fit, but i was also watching a purpose built toyosports one on eBay that came with n75, dv and map sensor already to go ended up getting it for £200 delivered so cant really complain its 64mm bore and i can always upgrade the core later on i was well happy till i came to fit it :/
    Got delivered and didnt look that well packaged so was a bit worried
    Got the box opened and was packaged well inside the outer box so all good, came with pipes, reducers, couplers, and clips all of which arernt the best quality but if i went forge for quality i paying and extra £400 so it does the job.
    started by taking out the battery and filter etc to make room
    took off the original boost pipe from the turbo and started to work it all in
    hung the core in the center using two long bolts going straight through the crash bar
    worked the drivers side up and it wouldn't fit with the head light in so had to really squeeze and move the pipes about till eventually had enough to grip it to the throttle body, it looks a bit bodged but it on there solid and would be amazed if it came off
    atm the pipe is squashed up against my hid wires hoping it wont get hot enough to melt them.
    worked the pipes from the turbo end and was again a tight squeze under the strut and above my oversized tip :/
    ended up having to hack away at my heatshield as i didnt want to get rid of it
    got a bit too trigger happy with the grinder
    the hardest part was getting the pipe onto the core it was miles out so had to rework it again and finally got it... just
    Dv and n75 connected up with a little trimming of the original hose's
    Now ive just spent the whole morning trying to get the bumper on and it would not go, was miles out i think where i fit the core so far forward however as with the rest of the build thread i went the route that most people will find fugly :D. will take some pics tomorrow also need to sort out my exhaust as its blowing from the center clamp and a new gasket on the down pipe
    s33nyboy12 and JudderMan like this.
  10. #209
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Awesome thread mate.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  11. #210
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    I found the toyosport actually a3 kit a awful fit to get the bumper on I brought a 2.25 inch universal toyo sport kit and fits perfectly hidden behind the bumper bit late to say tho sorry bud
  12. #211
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Quote Originally Posted by A3-Lee View Post
    2 25 UNIVERSAL INTERCOOLER KIT TYPE S 550x140x62MM 160 99
    This one? Did you manage to keep your fogs? I can't quite see in your avatar.
    @OP Tim, did you feel much difference after fitting the strut brace (and/or tyre wear?)? Do you have any others ie. rear brace and can you get a lower front and rear brace for A3s?
  13. #212
    Nov 2012
    Kent
    459
    Quote Originally Posted by JudderMan View Post
    did really notice any diffrence mainly as i fitted it as soon as i got it, i just liked the look of it to be honest. i dont have any others as i wouldnt imagine id feel any difference on the roads from my house to work, if i went down the track route i would tho.
    Yeah the FMIC fitted horribly i dont dare upload a picture of it atm as not even i find it funny ha, currently working 7days a week and with training i have no time to fit it "nicely" have set aside the bank holiday to re do it tho hopefully going to fit the core further back and will fit better we will see.
    Also thinking about changing the colour again, not sure weather to go "nice" and do all black or go for something funny like chrome or pink etc just for a month or two just to brighten up the world :D
    JudderMan likes this.
  14. #213
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Yes mate that's the one and I think you could easily keep the fogs
  15. #214
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Come on Tim you've gotta post a pic just for comedy values lol
  16. #215
    Nov 2012
    Kent
    459
    Haha i will do, im gonna re-do it on monday but will take a picture before hand and post it up as a before and after, but dont say i didnt warn you!
    s3dave likes this.
  17. #216
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Really that bad?
  18. #217
    Nov 2012
    Kent
    459
    Ha yeah it really is! And that's coming from me
  19. #218
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Quote Originally Posted by Tim_Attard View Post
    Lol you make me laugh mate nothing seems to put you off it's a great attitude to have dont you ever get fed up?
  20. #219
    Nov 2012
    Kent
    459
    what would be the benefit of getting fed up? i do have days were i cant be arsed but why waste life after all i could die tomorrow.
    superkarl likes this.
  21. #220
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Great attitude mate fair play
  22. #221
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,380
    Tim, go pink wrap mate, brighten the world up....... Then go matt white, then Kawasaki green, then maybe cadburys twirl purple followed by lamborgreeny ! :-D
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
  23. #222
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Cadburys purple would defo be a massive
    Vex182 likes this.
  24. #223
    Nov 2012
    Kent
    459
    Quote Originally Posted by s33nyboy12 View Post
    Sean
    Haha i have been thinking chrome or pink atm but they do an apple green which might be good
  25. #224
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    Any pics yet Tim
  26. #225
    Nov 2012
    Kent
    459
    Ha sorry mate i had to sort out the house as we are moving, but i will be doing it weds evening/Thursday so will get some up then
  27. #226
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    No worries pal hope the move goes well
  28. #227
    Nov 2012
    Kent
    459
    Got home from work around 8pm so started to take the bumper off and move the pipes around to get a better fit, stopped for the night now as i cant be arsed to carry on tonight and will finish off tomorrow but in the mean time here is a picture of what it looked like and what ive done to the bumper just for the banter, i have some rs6 type mesh which im hoping will look alright if not i will buy a new lower half.
  29. #228
    Nov 2012
    Kent
    459
    Ok so finished it off this morning.
    reworked the cold side, now it sits flush with the TB and is perfectly straight which i like.
    made up some brackets to push the core back and up a bit which means the bumper also fits a lot better now.
    as you can tell its not 100 straight this is because no matter how much i reworked the turbo side i couldn't get the pipe going to the core any further up, i think its because the 90 degree pipe that goes under the battery isn't really 90 :/
    bumper back on and happy with the fit but not over the moon on how it looks so im going to keep my eye out for a cheap front bumper BUT this means if i replace the bumper i have to re-wrap the whole car (as i wont be able to match the shade) or just leave the lower half black like a standard a3 so im thinking it will stay like this for a while.
    also my IAT's is reading at 28-32 degrees when i went for a drive ambient being 25 is that ok?
  30. #229
    Nov 2012
    Kent
    459
    FOR SALE?
    well unfortunalty after everything and finally getting it to a point where i was happy with it i know longer have a job to keep it going :/ awkward.... so im thinking about selling as i could do with getting a cheap car to run about in. im thinking around the 3k mark but am i pushing it abit there? do you guys think id be better to return it back to orginal colour?
    Cheers for any advice be a pleasure guys
  31. #230
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    i would De wrap it YES
    i got my daughters mint 04 8P up at £3500 1.6 sport low miles
    no takers as of yet
  32. #231
    Nov 2012
    Kent
    459
    would love too, but im looking around the £1k mark and a job in McDonald's :D haha
  33. #232
    bez101's Avatar
    Jul 2008
    8,492
    no i wasnt tyring to sell it you
    i was pointing out there not selling very well at the min
  34. #233
    Nov 2012
    Kent
    459
    Oh haha i get ya
  35. #234
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Shame to sell after all your hard work mate.
    Take the job at maccy D`s and start wrapping cars as a side business and keep the car
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  36. #235
    Nov 2012
    Kent
    459
    Right so im pretty sure im sorted job wise but not rolling in it, so Ive put the car back to standard colour almost and will try and sell but not at a stupid price if it doesn't sell i will keep it and do a bit more work on it.
    here is how it looks atm?
    If i keep it i think im gonna have to get a new turbo as im almost 100% its making a dogey noise.
    new lower part of the front bumper
    Battery relocation
    move the air filter and heat shield to the battery spot with custom heat sheild
    18's with winter tyres
    Spacers
    Paint/Polish Engine bay + tidy
  37. #236
    bez101's Avatar
    Jul 2008
    8,492
    looks better
  38. #237
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,380
    Looks better tim, don't sell it mate.......beg borrow steal earn all options
  39. #238
    Nov 2012
    Kent
    459
    ta yeah i agree it looks nice, this was without a wash too so looking forward to better weather to give it a good go, also think im gonna spray the gauge holders black
  40. #239
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Hi Tim, where did you get the heat shield for the air filter?
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
  41. #240
    Nov 2012
    Kent
    459
    got mine of ebay £25 there not bad but wasnt much room with an s2k
  1. MAX POWER - SOUTHEND MEET 6/6/09
    By ROLTYA3TURBO in forum Smaller (Local) Events
    Last Post: 4th June 2009, 18:09
  2. max power on stock AAN motor
    By jevrem in forum Classic Audi Forum
    Last Post: 14th June 2008, 12:49
  3. MAX POWER AUDI A4 LOL
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd December 2007, 08:36
  4. Max Power Candidate standing in Southend vote 4 free boob jobs!
    By imported_Yaseen in forum General Chat
    Last Post: 3rd May 2005, 10:25
  5. Don`t you just love it when people grow out of thier max power phase!
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2005, 17:32
