Badger5JMB Retrofits
Results 1 to 23 of 23
Like Tree4Likes
  • 1 Post By Westy
  • 2 Post By vfr800
  • 1 Post By ShaunS3
Thread: catch can only collecting water?
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    Hello guys and girls.
    Installed a can about a week back now went reasonable ok kinda :/ but im doing some work and thought id check it over and found the hose from the filter housing has quite a lot of water from condensation in it, i have pored it out and then checked the can and when i emptied it it looked like this:IMG_20130424_165933_740[1].jpg is this normal?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    yep looks normal
    leave it a month and check again
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    yep looks normal
    x2
    leave it a few weeks then check it.
    it will look like sewage water
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Nov 2012
    Kent
    459
    ha ok brilliant cheers guys will post back in a month
    Nov 2012
    Kent
    459
    i does still collect a lot of water in the hoses as well is this also normal?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Yeah,a lot less than if you didn't have the tank though
    Word!!!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Better to catch It then put it back through your boost hoses and into your engine
    Tim_Attard likes this.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    Has anybody who has installed a catch tank venting to atmosphere (i.e. no vacuum pull from the TIP or inlet manifold) found this in their catch tank?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by Alex C View Post
    I have, but only when I've forgotten to empty the can for a while. The thicker sludge and the watery stuff seperates as it cools down so you end up with a load of water coming out then the sludge.
    I now try to empty the can at least once a month and when the engine is warm as the can will be warm and the mixture drains a bit more freely.
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,601
    thanks, i think i've only seen posts off people stating they haven't caught anything or only some water making me think this catch can mod wasn't up to much
    Alex S3 AMK
    Westy's Avatar
    Dec 2008
    17,273
    Anything it catches and stops from going back into your engine is a bonus. The difference between how my boost hoses used to be and how they now are is unbelievable!
    S3 Build Thread
    Nov 2012
    Kent
    459
    its 100% worthwhile i was just unsure if i had done it right but i can tell you just from the amount of s##t i took out the orgianl hose its worth it
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Same here - I tend to empty the can once a month or so after the engine's warmed up. Typically I just get some brown water that smells of oil/petrol fumes, with occasionally some thicker content dispersed in the liquid. All seems OK to me in the pic above.
    SEAT owner
    Mar 2012
    Worcester
    77
    Get similar out of mine, got this lot last time i emptied it
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Sure that's not the sauce from your takeaway?
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I can't bear seeing these threads with pictures of the gloop that's going back into my engine.
    I've just sent Mr Saikou some of my hard earned cash and he said he will send me one of his sought after catch cans :P
    Wooohoooo!
    dre_S3 and Tim_Attard like this.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Oh yeah!!!! Look what arrived today!!!
    Nov 2012
    Kent
    459
    is this normal?
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    I checked my catch can the other day and it was bone dry :/
    I'm pretty sure its set up right as the outlet pipe (vent to atmos) is pumping out gases, so i presume its doing its job.
    Could it be my engine is really healthy and not pumelling aload of rubbish out of it or do we think there is something a miss as to why the catch can is still bone dry?
    Shaun.
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    I'd say that's normal for this time of year. I usually only get mine filling up during the cooler months.
    S3 Big Turbo
    Westy's Avatar
    Dec 2008
    17,273
    Mine still filled up straight after an engine rebuild so I'd be more worried if yours is bone dry!
    When I first fitted my can I thought the drain screw was shut when it was actually open. I thought I was opening it to drain It and it was bone dry. I then noticed oil below it where it had been draining out onto my sub frame. Could this be happening to you?
    Also do you still have the 1 way hockey puck valve?
    S3 Build Thread
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    Quote Originally Posted by Westy View Post
    Well, my catch can is slightly different in terms of that mine has a level checker tube so that i can see when it needs draining. This has got an oily tint to it now but doesn't seem to be filling up.
    The butterfly drain valve is screwed up to the top (the way it came). I checked the drain tube with my finger first to check if it had been on a constant drain as you say but it was bone dry, so i then opened it up right to the bottom of the thread and nothing came out at all.
    So i pulled off the pipe from the rocker cover that goes into the inlet and again, bone dry with no major oil residue on the tip of the rocker cover outlet, which then suggests its not pumping aload of rubbish into the catch can, although the pipes did have the oily fumes when sniffed.....
    As for the hockey puck valve, that got binned and a blanking plug into the TIP where it used to go...
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    Phew.....finally drained something out of the can today
  1. BSH Catch can group buy offer - CLOSED
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2009, 09:35
  2. Can only start car with master key - immobiliser problem
    By voteforpedro in forum General Technical / How To
    Last Post: 13th August 2008, 17:16
  3. Bloody tyres - need 4 got a puncture in 1 & can only afford 2
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 13:22
  4. Can only Audi change the Gearbox oil in the auto tiptronic boxs?
    By rich dj in forum General Technical / How To
    Last Post: 15th November 2006, 10:08
  5. I need a car that can travel on water like Lord
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st August 2004, 21:45
