EM TuningChris Nott
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Battery Drain
    Jun 2007
    614
    Battery Drain
    Hi folks, has anyone with an S3 ever checked the drain on the battery when the car is not running? What value is acceptable?
    Of course with the S3 having an after run pump I am talking about the drain after this stops
    Any help appreciated!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    I have had a drain issue... 3 days without driving the car and its flat... it was the stereo in my case, left the amps and headunit disconnected and after a week the car started with no issue at all so I rewired it and will be checking the car tomorrow to see if its cured...
    They will always drain a little... alarm etc... not sure how long they normally last though as I normally disconnect the battery if I know the cars not being driven for a long time...
    My Mk2 Golf however has been sat for 6 months before and still starts first time
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Dont know, but i would like to know too as i have a brand new Bosch silver and its dead after 2 days..
    Danno57's Avatar
    Apr 2011
    Taunton, Somerset
    44
    Mine usually lasts around a week and a half if its not being used.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Do you have an after market stereo Dave? if so how is it wired?
    <tuffty/>
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    402
    Disconnect the earth from the battery put your multi meter on 10amp scale place red lead on battery neg and black lead on earth lead anything more that 0.5 amps is excessive remove fuses 1 at a time and watch the reading when the current draw drops to below .5 amps the draw is on that circuit hope this helps if you need a hand just pm
    Lee
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    <tuffty/>
    Yes it is wired with the normal adapter, but you can hear noises from the amp when the face is off when you clear fault codes etc.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Is it wired to go off with the key? I wired mine to be permanently on originally (something I have done for years) but also had a 4gb USB stick permanently connected... have now rewired to the ignition and removed the USB stick... will see if this cures my issue tomorrow when I move the car...
    <tuffty/>
    Jun 2007
    614
    Quote Originally Posted by A3-Lee View Post
    Lee
    Cheers Lee. This is what I read somewhere, that in general you shouldn't see more than 0.5amps. Just wondering if anyone has any figures from testing this on an S3 themselves.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    <tuffty/>
    No it stops on with the key removed,, Hmmmm i have one of them tiny flat usb sticks in too, watching with interest..
    It Also does not unlock the doors unless you remove the facia for some bizarre reason...
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    It will also depend on how healthy your battery is. I've just replaced my 6+ year old battery and everything is sharper on the old girl now. Starts so well too.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    I hard wired my 'accessory' feed from fuse 37 (s-contact)... this isn't wired into the std ISO plug..
    Where to find a ignition live - any pics?
    <tuffty/>
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    520
    had same issue. See post #21 - #24: Xreg Imola Yellow S3 - Project post
    My battery drain is 0.2A
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    711
    I wouldn't accept 0.5A as a healthy drain. That's quite a bit.
    100-250ish milliamps is about right on these motors.
    Audi S3 1.9 GT30....
    ....that is all
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Little update... since rewiring the head unit to turn off using s-contact (fuse 37) accessory feed AND removing the USB drive I can say that this has improved things no end... too soon to be definitive of course but the car was unused for 4 days and started first turn... typically 3 days and there isn't even enough juice to open the locks...
    Happy bunny again... phew
    <tuffty/>
    s3dave likes this.
  1. Please help (strange battery drain)
    By mrlinderley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2009, 20:12
  2. Annoying Battery Drain
    By sterlacchini in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2009, 21:16
  3. A4 Battery drain-help
    By audimike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd December 2008, 07:24
  4. coupe battery drain
    By andy64 in forum Classic Audi Forum
    Last Post: 13th February 2006, 12:43
  5. Battery drains out in a day.
    By mashoud in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th November 2004, 07:36
