Badger5JMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
Like Tree9Likes
Thread: Tie Bars fitting help!
  1. #41
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    I had to 'assist' my local guy when they did mine but thankfully they were quite receptive and set everything up fine...
    Most wheel alignment places are used to dealing with std setups on std cars... you take some thing exotic in and it can phase them a bit... clearly (as Karl has mentioned) this can be also said of companies in the tuning sector too...
    There is a decent write up in the stickies concerning suspension set up and the best bet is to take it too a place with a decent laser alignment rig and tell them what you want and how you want it done... should all be good then
    <tuffty/>
  3. #42
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    I asked him about it and he said that he said he just adjusted both arms so that the wheel didn't hit the guard but also didn't cause the driveshafts to bind. I had asked for ~1 degree rear but he said he got as close as he could while maintaining zero toe. He said that 1-1.5 is ok as long as there's not too much toe. Perhaps the trailing arms on mine had already been adjusted? I was chewing through tyres fairly well before though. Lucky the AD08s hadn't been on long.
    The guy sets up race Porsches (had a few nice 911s in when I went), R8s, Evos, WRXs etc for Targa, Rally, Race etc and is very well regarded. He really has done an awesome job. The car used to feel a little sketchy sometimes but with the rear setup and the camber up front reduced, it feels really solid. I think I'll run out of balls before the car does! I keep banging on about it I know...
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  4. #43
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Yeah I only took mine to the local tyre place to get the toe on the front sorted. I drove about an hour south of Sydney (2hr train/bus journey to pick it up) but it was worth it.
    When I went for the toe adjustment at the tyre place the guy had a proper aussie accent and went "blimey mate, she's running nearly 3° camber" and went on to say it'd kill tyres etc...
  5. #44
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,598
    Quote Originally Posted by kwistof View Post
    As you've replaced the bottom ones, do you now need to get the sensor re-calibrated as per what Forge says in post #16?
    S3: Forge tie bars won't allow adequate adjustment...HELP!!
    Nope, I marked the distance on where it was fitted on original bars and bolted it up, job done.
    kwistof likes this.
  6. #45
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,598
    Right, small update, I put the bolt back to front and it was 100 times easier to line up, so one side done, driver side next, which should be a doodle, now I know what to do!
    Cheers!
    [Dave B] and s3dave like this.
  7. #46
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    😄 Wheyyyyy
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
  8. #47
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,919
    Quote Originally Posted by jojo View Post
    Cheers!
    Wait until I come over and sort it
  9. #48
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,598
    And so the driverside was a piece of cake once I sussed how to do it! I have to admit, as a one man job on axle stands, it's not for everyone, an extra pair of hands would have made life easier.
  10. #49
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Should of called me!!! I would of come!
  1. Roof Bar Fitting Help
    By manzi in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2009, 17:01
  2. S3: Forge tie bars won't allow adequate adjustment...HELP!!
    By Dennis Moeller in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2009, 07:29
  3. Tie bars, Coilovers and ARB fitting costs!
    By Olly P in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2009, 19:02
  4. Replies: 16
    Last Post: 9th August 2009, 14:09
  5. Tie-bars fitted
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2007, 20:57
