    Jan 2009
    West London
    269
    Accelerator Pedal vibration/shaking
    Can anyone shed any light on what might be causing the accelerator pedal to vibrate and almost a knocking noise from what seems like the offside driveshaft when applying load to the engine? I replaced the driveshafts yesterday so have ruled those out now. It's more evident on the offside as when I turn left it judders a bit more and makes a noise. If I am pulling away from a standstill it is far more pronounced than if I was cruising at say 50mph and if I put my foot down it's also really evident then. It has only just come about after pulling the engine out to replace some parts. Everything was fine before that so I don't think it is related to the wheels or a balance issue. Nothing is knocking either from what I can see. The only thing I can think of now is that the engine mounts might be going soft but then it still seems strange that it feels as though the problem is right behind the accelerator and more of a rotational problem. I have the uprated THS mounts which have been on for a couple of years now but probably only seen about 5000 miles so even that seems unlikely too.
    I've read through all of the previous vibration threads on here and on other sites but can't seem to find a definitive answer so was hoping someone may have had a similar problem. Thanks for any info.
    May 2012
    RETFORD, NOTTS
    1,753
    Almost the same as my tdi right now. engine was out recently but done 2-4k miles since, sudenly appeared over 2 days. steering also feels very vague.
    So far changed the dog bone mount, bashed the heat shield above the exhaust, I think ill replace the other two mounts. the one above the gear box moves around easy with a pry bar.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    May 2014
    Unhappy i've the same problem and i couldn't solve it till now did any one know how to solve?
    i have the same problem and i couldn't solve it till now did any one know how to solve? the pedal pulses when accelerating and it's very annoying thing...
    ToonRing-G's Avatar
    Audi Virgin
    Jan 2013
    Renfrewshire
    62
    knackered flywheel perhaps?
  1. Vibration from accelerator pedal
    By Meallbhan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd April 2010, 23:38
  2. How does your A4 drive - vibration through accelerator pedal?
    By PATCH in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2009, 18:12
  3. accelerator pedal
    By Mustafa4hmed in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2005, 12:46
  4. clutch pedal vibrating
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2004, 21:12
  5. 1.9 TDI Serious Clutch Pedal Vibration
    By matt_splatt in forum General Technical / How To
    Last Post: 13th April 2004, 22:53
