EM TuningAH Fabrications
Results 1 to 10 of 10
    TOTE's Avatar
    Just Me
    Jan 2011
    London
    97
    Add TOTE on Facebook
    Help on garages prices
    Hi i have been quoted £205 to replace the alternator pulley,as its seized and making a horrible noise.
    I live in sw London,can anyone recommend me a reasonable priced garage in this area thanks.
    Jan 2011
    northants
    165
    the only one i know in london is russell automotive
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    You sure it's the alternator pulley?
    To remove/replace the ribbed-belt is pretty easy, with a spanner and an old drill bit you can lock the tensioner back. The alternator pulley is held on with a big bolt. Seems a pretty easy job to DIY.
    When my aux/v/ribbed belt was screeching it was in fact a seized aircon compressor & aircon clutch/pulley which ended up costing me over £1500 at the Audi garage. And is a common problem ...
    Assuming you have aircon / climate control ...
    If it's actually a seized aircon clutch the garage is replacing then they're getting on for £100-£150+ for an OE part.
    I'd make sure the garage has diagnosed it properly, it would seem expensive to replace the alternator pulley.
    You can test yourself ... does the aircon disengage when you press the econ button?
    If the screeching goes away when you press the econ button and comes back when you turn aircon back on I think it's the aircon compressor.
    If the aircon doesn't disengage when you set the econ mode, then it's your aircon compressor clutch. Maybe.
    Or if that all works as it should, I have no clue and you can ignore me.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    717
    volks autos ?
    In Sutton, just about in London.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    Quote Originally Posted by vfr800 View Post
    Liam
    If it the clutch type pulley you would need a special tool (shockingly!) to remove it... the pullies are fairly cheap...
    ALTERNATOR FREEWHEEL CLUTCH PULLEY 904VG0200
    13 PIECE ALTERNATOR PULLEY TOOL KIT | eBay
    <tuffty/>
    TOTE's Avatar
    Just Me
    Jan 2011
    London
    97
    Hi thanks,i have tested and wen i turn on the air con on the climate control.(the temp on the lowest possible the noise goes away)only came back wen i switch off the air con.just noticed that wen turning the steering wheel it makes more noise,but if i accelerate above 1000 rpm it goes away,now i am confused.
    BENJAMIN's Avatar
    Mar 2011
    460
    Quote Originally Posted by stote View Post
    That does sound very much like an alternator pulley issue. It doesn't do it when you have the a/c on as you're putting extra load on the belt, or above 1000rpm as you're taking the inherent harsh diesel idle away. This issue only really becomes apparent on the Tdi as it makes the steering judder and 'chirp' if at idle speeds, because the 1.8t is a smoother engine it doesn't get affected with the issue even though the pulley does seize up just as commonly.
    Its easy to change, and can even be done without removing the alternator if you use the special tool. Another option would be for you to remove the alternator yourself and take it in to a local garage and ask them to fit the new pulley for you, they'd probably only charge you £20 or so.
    2008 8P S3- Black edition. 'all the options....'
    Oct 2012
    birmingham
    197
    i can suppley and fit you a genuine pulley for £80 but you will have to come to birmingham
    TOTE's Avatar
    Just Me
    Jan 2011
    London
    97
    Quote Originally Posted by BENJAMIN View Post
    Thanks for this really good explanation Benjamin,
    TOTE's Avatar
    Just Me
    Jan 2011
    London
    97
    Quote Originally Posted by Sham101 View Post
    i can supply and fit you a genuine pulley for £80 but you will have to come to birmingham
    Thank you Sham101 if it was a bit closer i would take your offer.
  1. can anyone help put a price on this wine?
    By James TQ in forum General Chat
    Last Post: 27th July 2012, 10:17
  2. Garage Prices reasonable ?
    By MingeBlue in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2011, 12:16
  3. Help with parts prices!
    By M Dogg in forum Classic Audi Forum
    Last Post: 12th March 2008, 08:05
  4. need help with price
    By Barryodoc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2007, 14:30
  5. 18" Alloy Price Help Please
    By peanut in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2003, 11:52
