EM TuningVolks Autos
Results 1 to 8 of 8
    Oct 2012
    Aberdeenshire
    26
    S3 air bag light, resistors or remove it all?
    Hi all, I've stripped out my year 2000 s3 and I'm going to be using it for a weekend toy / track day car, since removing the seatbelts and seats that were all wired in the air bag light has came on, I've done some searching and seen that you can wire in resistors to fool the system, but i can't find what type I need and where to get them from?
    I've also read some people removed all the air bag/pretensioner wiring and blacked out the warning light, is it easy enough to get behind the cluster on an s3? Also will it still pass the MOT even if the light doesn't come on when the ignition is turned on?
    Which of these would be the best option in your opinion, any help would be great, thanks Gary.
    Cobra88's Avatar
    Sep 2011
    Live in Ipswich Suffolk (orig from W London)
    436
    Measure the resistance on your old seats airbag plugs
    then Maplin, eBay Resitors matching the resistance you get from the seat airbag plug
    not at all hard
    2004 Audi A4 (B6) 1.9Tdi 130 Sport (6) Avant in Dolphin Grey.
    18" S4 AVUS, RS4 Rear Roll Bar, Leather Alacantra Sport Seats, Shark Performance 170 Remap,
    BOSE, XtronsA4A double din, Full DIS, Autolocks & Alarm Chirp.
    Avant Sport 1.8T Valance with twin exit.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Cobra88's Avatar
    Sep 2011
    436
    that's cool tufty
    Not seen those for the airbags.
    Was pleased when I recoded my ABS after upgrading to 312mm front brakes.
    Handy stuff
    Oct 2012
    Aberdeenshire
    26
    Thanks guys!
    <tuffty/> will give that a go looks simple enough
    Oct 2012
    Aberdeenshire
    26
    Right guys, i plugged in the Vag com and it let me in to turn off the passenger air bag but all the other channels just say error and it can't read them, could anyone shed some light on why that is? Cheers Gary
    Jun 2004
    Surrey, UK.
    269
    Hi,
    need to replace the front passenger airbag -how do I remove it ?
    I've found the torx screws behind the plastic cover and the two in the glovebox.
    What else needs to be removed?
    I understand I need to remove the battery before disconnecting the airbag unit itself.
    Jun 2004
    Surrey, UK.
    269
    I've found the A3 interior manual - so I'll use that.
    Any hints/tips ? (apart from read the manual)
  1. Air bag light - on for no reason after removing dials?
    By Michael2013 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2013, 21:33
  2. air bag light
    By a4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th November 2006, 21:08
  3. Air bag light
    By imported_alex100a in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2006, 21:30
  4. air bag light and wing mirror?
    By imported_spleenboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2005, 17:38
  5. Air bag light !
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2005, 17:48
