Chris NottVolks Autos
Results 1 to 16 of 16
    Apr 2013
    Budapest
    17
    A3 8L - ASZ 2003 PD TDI - All the problems you can get
    Greetings to All
    Try to make it short (won't make it ).
    Bought the car in February this year. It was more than a bargain! My first Audi and PD TDI. I knew it would have a few probs but now its more than you can imagine.
    First of all, blinking sign on dash - laptop (VAG) says it's only around 70-80 fault codes. Still the car was working, consuming fairly well and runs 'fast'. ESP/ABS is not functioning (should be a sensor failure possibly) also water temperature gauge is faulty.
    But 85 codes, c'mon! Here is a few from the list: AC F129, temperature sensor vent. V42, sunlight sensor G107, Airbags 7008, central locking D16, interior lights, navigation, parking system A3 RDW D18, rear right rpm sensor G44, ABS, quattro control (?!), and so on.
    TO be honest, AC is not working, also the small lights above my head is not working. Parking aid was working until last week, now it only makes the constant noise. It is not quattro so no idea why it says quattro control fault. Navigation probably not wired.
    The biggest one is I guess that I found out that above 130 Kph (~80 mph) I am losing the turbo boost. After a restart it's back but I can't do speeding right now :D
    I'd appreciate any advice except burning it down :-)
    L.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Got a proper list of the fault codes? preferably from a scan with VCDS?
    As mentioned in the other thread your VNT could be sticking and overboosting putting the ECU into limp mode...
    Scan the car using VCDS, use the links in the stickies to research the fault codes (link to this thread is also in my sig) and post up the results
    <tuffty/>
    Apr 2013
    Budapest
    17
    I do have the list, however it was read with a Hungarian software therefore most of the fault codes useless for you I think. But I'll get them today somehow with the code numbers.
    I'll be back with the results. Thanks for your fast response and help!
    <tuffty/>
    Apr 2013
    Budapest
    17
    Here they are. Full hunagrian or german at some places. Hopefully the code numbers can help instead. Apologies for the quality!
    http://s2.postimg.org/ko1vcvsm1/DSC03024.jpg
    http://s2.postimg.org/9pqlup40p/DSC03025.jpg
    http://s2.postimg.org/p8o1rtcbd/DSC03026.jpg
    http://s2.postimg.org/sw3sxvkih/DSC03029.jpg
    2003 A3 5d 8L , ASZ - PD TDI - 96 KW/310Nm and blue like that 8-)
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    have you cleared them and seen whats come back? sounds obvious but some people miss that it could have all the codes from its whole life stored if they've never been wiped as far as quattro i dunno whats going on there??? check its the right ecu maybe?
    1999 apy s3, black & blue interior,dare bbs lm's, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, stock dump valve, badger 5 v3 tip, bam rocker cover and push in coilpacks, toyosports fmic, amd stage 2+ remap 280.3bhp 263.9 lb/ft.
    Apr 2013
    Budapest
    17
    Yeah, I am thinking about the same as for the quattro thing, perhaps an incorrect ECU version, but still unclear the whole story. The car is from germany by the way.
    I had no chance clearing the codes then checking again. I have no VAG or VCDS around. A friend read it for me last time. Since then I have the parking aid failure and the turbo boost issue as new probs.
    Would it be a VNT problem for real, what should I do?
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    not sure.... the vcds cable is only 6 quid on ebay uk, the software is a free download from rosstech! take a look mate... mayby your friend used his code reader wrong and got quattro up that way!?
    Apr 2013
    Budapest
    17
    True! The reader could be wrong as well (the firend is a mechanic thou') but tomorrow I am taking the car to a Vw-Audi garage, I just wanted to know a bit more in advance and also not willing to loose too much money on changing every single part.
    Interesting fact I have a quattro glovebox door!
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    ??? did they make a diesel quattro in germany?
    Apr 2013
    Budapest
    17
    Nah, I do not think so. I'd rather say it has been put together from a diesel and a quattro... but no way to find out the truth I guess.
    Apr 2013
    Budapest
    17
    one word
    So I just got it back from the service station. It turned out I have an incorrect ECU version probably from a quattro. Lots of wires have been unplugged and cut in half. Probably I have a stucking issue with the VNT as said by tuffty earlier. Turbo needs to be cleaned. Parking aid could be either the control box or wiring problem. Generator driver needs to be changed as well. ABS and ESP is not working, also control unit failure (not correct unit). Interior alarm is not working, there is no wiring to it at all. A/C compressor possibly wrong as well. None of the 10 airbags are working! Incorrect control unit again...
    That is a fortune.
    I need to sell it as cheap as they buy it. It is almost impossible to amend all of these things. Or it would cost the price of the car...
    Totally dissapointed. But to be honest it was(the car) so cheap when I bought, I knew something similar is going on.
    justarn's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    587
    hard luck mate and good luck...
    Apr 2013
    Budapest
    17
    I might need that! Thanks!
    Apr 2013
    Budapest
    17
    Meanwhile, I need to take care of a few things.
    I have been told that the turbo needs to be cleared/cleaned (?) also there is a valve that controls the pressure located near by the firewall. Can this cleaned too or it is better to change?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    VNT... fairly normal to get clogged and normally symptomatic of over boost issues... as I already mentioned in the second post of this thread
    <tuffty/>
    Apr 2013
    Budapest
    17
    Understood I was only wondering what to do with the valve since I have an error code with it as well.
    <tuffty/>
  1. BHP torque whats the max you can get out of ko4 turbo
    By S3 GEORGE in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2009, 21:39
  2. List all the cars you have owned so far
    By julians in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2008, 22:17
  3. no speedo.....the problems continues and gets deeper......
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2007, 22:55
  4. Anyone know where you can get these in the UK?
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th April 2005, 16:21
  5. Oh Dear - maybe the worst loaner you can get...
    By audi_girl in forum Other Brands & Models
    Last Post: 20th April 2004, 17:46
Tags for this Thread
