Volks AutosChris Nott
Results 1 to 10 of 10
    Mar 2013
    49
    Possibly Faulty Temp Gauge ?????
    Right,
    Ive been seeing some strange goings on with my temp gauge.
    Basically when i get in the car in the morning and the car is off my temp gauge needle is all the way off the markings.
    When i then turn the car on it sits at 70 straight away.
    When the engine is was i would expect it to be no hotter that 90, however the other day after driving for about 30 mins it went all the way up to 105 ish!
    Now i think that this may be a misconfigured temp gauge given that my fuel gauge is also misconfigured by 1/4 of a tank.
    Ive checked my coolant level and its sitting well above the min line. I have attached pics of the gauge when the car starts in the morning and when it got hot the other day. It went up a little higher but i haven't got a pic
    Any ideas guys?
    Mar 2013
    49
    Also, does anyone know roughly how long red powerflex dogbone bushes take to wear in? ive done around 300 miles on them and the vibrations went from very bad to bad and now there still worse than with the oem bushes i had!
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    my poweflex bushes took around 1000 miles to bed in.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Mar 2013
    49
    1000 miles?
    Does anyone know if there is an official figure for wear in time?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    i got the yellow dunno if that makes a difference or not.
    but mine took around month to bed in, i do around 250 miles a week.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,928
    it could be the CTS
    Mar 2013
    49
    Yeah from reading about i thought it could be the cts. Ive seen there is a secret mode in the climate control to show engine temp. if it matches the temp on the gauge then its all fine. if its out then there an issue whihc could be cts or temp sensor/ gauge.
    is that the best way to pinpoint the issue?
    Mar 2013
    49
    Ok,
    Anyone know what the best setting in the climate control "secret" mode is to use to compare with the temp gauge on the dash? Im doing a 60 mile trip tomorrow and that would be a good time to monitor the differences.
    here is a list of all of the secret modes AudiWorld Tech Articles
    I was looking at 51 today and it was well off but this might not be the best one to use.
    If this is a silly way then whats the best was of seeing if the CTS is a fault?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    hold the recirc button and the up arrow
    then pressing the + button untill you get to the number you want.
    then press the recirc button to show the data result
    i think its 49 for coolent temp on mine.
    Mar 2013
    49
    I used this one
    51 Engine Coolant Temperature (ECT) in deg C
    it was showing 51deg and the dash gauge was showing 79deg. the gaugye was going up, didnt go down once but was only in the car for 10 mins.
    when i got in the car the gauge was sittin at 70??? but when ive not been in the car for a longer time it the temp and fuel gauge go off the end of the scale. is this normal?
    any suggestions?
  1. possible faulty temp gauge a6 2.8 30 valve
    By yendall24 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th July 2009, 12:18
  2. Temp gauge
    By imported_Gytha in forum Detailing
    Last Post: 17th July 2005, 19:48
  3. A6 2.5TDI V6 temp gauge falling and rising??
    By imported_Auditurbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th June 2005, 00:44
  4. Help with my Temp Gauge
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2004, 09:53
  5. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
