JMB RetrofitsEM Tuning
    nicksthebiz's Avatar
    Nov 2012
    Hayle, Cornwall, UK
    163
    Replacing interior lights with LED's
    Just a quick couple of pics on the interior reading and dome lights ....
    All thats needed is a flat head screwdriver
    This is a list of the bulb you will need for all interior lights(i only have a couple on pics but rest are self explanitory)
    When the bulb are replaced make sure to try them both ways round due to the postive and negative etc.
    For the front reading lights the clips are in the picture below
    Try and prise as close to the clips as possible ....
    They may feel stiff but they should give, if it doesnt feel right it probably isnt so take your time
    Then you will need 2x ba9s bulbs these twist in and out of the socket .....
    For the next part the main lights are 2x 44mm festoons
    Here is a picture of where the clips are these are hard to see my pic isnt ideal !!
    This is what it looks like after its of.....
    For the small light plastic holders underneath just push the edge toward the bulb and it should drop out.
    Then re-attach both covers remember test them before putting cover back on !!!
    Rear reading bulbs are 2x ba9s
    Prize out on left and right with a flathead screwdriver there are 2 metal clips should pop easy compared to other light
    These are abit harder to fit its fiddly but the ba9s bit they also twist in and out....
    Hope this helps its my first writ up on here if its not clear enough feel free to remove hope it helps someone
    S3 8L 2000 APY (bens S2000 Air Filter In October 14 Plus V3 B5 Tip Stage 1)
    Nick Jones,Cornwall UK
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
  1. Changing interior lights to LED
    By physk in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 20:28
  2. replacing existing top brake light bulbs with LED
    By thekyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2010, 00:34
  3. LED Interior Light Kit .....
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2007, 09:00
  4. Replacing Interior Lighting
    By Caesium in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th January 2007, 00:38
  5. Sidelight replacement with LED's
    By imported_ChristianF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd September 2006, 15:20
