Sky InsuranceChris Nott
Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: 2.0l block
    Sep 2012
    69
    2.0l block
    HI all my dad is having his or should I say wanting his s3 bored out but he has been told that his block isnt suitable for a 2.0l bore as the block in not a
    'wet sleeve' engine. Its apy 2000 engine same as mine and this is not something iv seen talked about. Is this fact or fiction?
    Audi S3 2000 APY. N249 Delete...... thats it so far lol
    Sep 2012
    69
    Also looking at an agu head. Are they all same I mean will the agu head from a golf have the same port size as 1 from an a3/s3 cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    For a 2ltr you will need 83mm bore stroker pistons and a TFSI crank that has been adapted with a 20v oil pump sprocket...
    AGU heads on a Golf are the same as AGU heads on an A3
    <tuffty/>
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    What you need is a stroker kit like mine or Staceys on here
    Mine is a stroker kit to take the engine out to 2.1 and staceys is a 2.0, Staceys is the better of the two as it has a better rod ratio. what you need is a different crankshaft from a 2.0 engine or like i have a TDI crankshaft. Look up stroker engines
    As for heads the AGU has a large port head which is better for big engine/turbo builds, This head also has bigger ports than your S3 head
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    ...I assume you are thinking of just boring the block to 2ltr? biggest sensible size available is 83mm (83.5mm is available but the bores walls are too thin at this point for reliability) and this takes the std stoke to 1.9ltr (1870cc)... for 2ltr (2008cc) you will need the TFSI crank...
    83mm bore also require a different head gasket...
    <tuffty/>
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    TFSI crank is the expensive route. You can also use a crack from a mk4 2.0 8v engine. They have the same stroke, only difference between them is
    mk4 crank is cast, has the correct oil pump drive gear and weighs 1kg more than the tfsi.
    tfsi crank is forged, oil pump drive gear needs to be removed and replaced with correct gear for 1.8 oil pump.
    why does he want a 2.0? Is he going to upgrade the rods and go big turbo?
    Sep 2012
    69
    Yea it will just be a re-bore to 2.0ltr. but psi tuning have said the engine isnt sutable for this due to it not being a wet liner. im not sure what they mean by this but i assume it would be to do with oil feed to the pistons?? I know the crank will be changed and a stroker kit will be more likely the way the build will go as hes unsure as to what turbo will be fitted at this point. 450 - 500 is the target as he just whats good power after buliding the car up 380 first time round. iv told him about your build tuffty and that the power he wants can be achived without a stroker build and i would imagine keeping it at 1.8 would be even more reliable again than just a strong 2.0ltr?
    Sep 2012
    69
    Yes big turbo is the plan but were just running threw all option atm to be able to build a good quick reliable car. like i said he built it the first engine some 9 years ago before alot of the parts used now wernt around so picking stuff out for this build is vast from what he worked with last time
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    Tuffy has/had a 1.8 with big power
    badger5 has a 1.9 with huge big power
    Andrew has a 2.1 with huge big power
    Then there are a lot of others that have big power using the 2.0 route.
    The best advice everyone on here will give you is ditch that PSI place and get advice from a place that knows what they talking about.
    You can also ask them how the mk5 gti is a 2.0 or the mk4 2.0 8v using the same block.
    Sep 2012
    69
    Psi are a "specialist" for vag tuning and built the original engine along with so many others. i understand what you are saying and it seems im shining a bad light on andy who owns it which im not doing because he does good work and its the closest bar awsome where andy learnt his trade from jim in the first place. but on the other hand this seemed abit suspect to me after never seeing this decribed before. but back to the build lol its early stages yet its just a reading and advice stage before jumping into ripping it to bits
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    Maybe the story isn't straight then. Maybe the mix up is they were asked if the engine could be bored to a 2.0 with the 1.8 crank.
    You have to stroke it to get 2.0
    Maybe you should speak to them again.
    Sep 2012
    69
    The question wasnt about the stroker build itself was just about the boreing. it was said a wet liner engine was needed for a stroker build which apparently the apy isnt? This is my confusion can it be done on a dry liner if that is the case?
    Jun 2009
    Leeds
    3,352
    FOR SALE
    Jun 2009
    Leeds
    3,352
    Sounds like PSI have got mixed up or you asked the wrong questions
    The block will need to be bored out a little but its the crank that gives it the most cc's and this can be done to a APY or any 1.8t block as they are all the same.
    FOR SALE
    Scullies's Avatar
    Feb 2012
    Dubai
    1,205
    All 1.8t 06a blocks are the same
    n/a 06a blocks are also the same but don't have the turbo coolant return line in the block. It's not drilled and tapped.
    so I would say its safe to stroke your engine to a 2.0 using a 2.0 crank and 83mm pistons - it's not cheap! Especially the 2nd time round
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Build a stroker... <end/>
    <tuffty/>
    Sam_ likes this.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,677
    could you not just drop a 2.0 TFSI engine from an S3 in there for less ?
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Quote Originally Posted by mattyboy199 View Post
    Would need the ECU and associated wiring.... there are kits for Mk4 chassis stuff available but if chasing 500hp build the bloody engine right in the first place...
    20v stroker built RIGHT will give you a good base for a 500hp car... get it done!
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    Quote Originally Posted by Birdy View Post
    Bore alone, which you have fixated on is limited by cylinder wall thickness and the bore seperation... ie it limits the max overbore you can run..
    83mm (from 81mm std) is the usual max overbore, and often 82.5mm is used.. You can contemplate bigger but the seal face for head gasket between the cylinder at that diameter is mighty skinny.
    I run 83mm bore std crank, which is ~1900cc
    Does'nt stop me making >600bhp from 26psi boost with suitable "other mods"
    Forget wet liners etc.. Irrelevant for this requirement/engine
    Want 2ltr, Stroker crank and 83mm bore is the answer as others have already said a few times
    None of the S3 motors are linered...
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sep 2012
    69
    <tuffty/>
    hahaha i love this post as this is what i said just do the stroker and go from there. so looks like ill be reading up on cranks now. thanks guys as helpfull as ever
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    i was wondering what all this talk of wet and dry liners was. Aren't they just a solid lump of cast iron?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    Quote Originally Posted by Alex C View Post
    yes..
    such is the misinformation from some folks...
    how bizarre
    bill@badger5.co.uk
    solaris's Avatar
    Slough, Berkshire
    399
    I have an APY block that's been rebuilt and stroked to 2008cc 9.0:1 compression ratio using Mahle Power Pak pistons, DM forged rifle drilled rods, TFSi crank and loads of other goodies. So that's proof it can and has been done. (Im fitting the block to my MK2 golf as we speak)
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    Quote Originally Posted by solaris View Post
    Its not a question of it cant be done tho dude....
    inserting liners etc,..... was the dubious thing stated by the op...
    rebore simples
    2ltr crank (or larger) simples
    liners? hmmmm.. not on a 1.8t block.... when you can do the above as "normal" simpler upgrades.
    Some have done liners, diesel block, 95.5mm crank etc... but thats a whole different ball game.
    bill@badger5.co.uk
  1. New Kid on the Block w/o the boy band overtones
    By moralkombat in forum The Welcome Section
    Last Post: 25th October 2004, 10:10
  2. new guy on the block
    By imported_nmb in forum The Welcome Section
    Last Post: 20th August 2004, 20:16
  3. New boy on the block
    By imported_scotthamilton in forum The Welcome Section
    Last Post: 16th August 2004, 10:50
  4. Cat Block
    By MisterD in forum General Technical / How To
    Last Post: 20th October 2003, 11:12
  5. New kid on the block
    By stobbie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2003, 22:09
