Chris NottVolks Autos
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By patTTpoa
  • 1 Post By <tuffty/>
Thread: What's happening? Is it the Awesome haldex unit?
    quattrokid's Avatar
    Jan 2006
    Ayrshire Scotland U.K
    220
    Ok.... Whats going on...( just had its 40'000 mile service) bought the car in January with 38500 miles on it , now up to 41500 ish) the yellow warning lights first came on dn route home from buying it in Wales.... the lights comes on regardless of speed or driving style...
    Brake fluid was changed twice,yesterday, this sensation of the abs kicking in sometimes under hard braking...
    scanned again absolutely nothing is bringing up any fault codes at all, he took some logs or whatever it's called and each wheel sensors regulator in the abs unit is spot on as well, wheel alignment was done and very slightly tweaked, the wheel
    sensors where all checked and all are in fine fettle, discs and pads don't look that old either...
    BUT STILL the yellow abs and traction control lights come on for no apparent reason, came on rn route to my Mums this afternoon.
    The only mod it's had is the Awesome haldex ecu has been upgraded for an aftermarket one. No vag com codes for that either, brake pedal does seem to have a fair bit of travel in it before the brakes bite
    I'm going to call Awesome tomorrow and ask their techy guys what they think. even with warning lights luninated there are no fault codes and non stored!!!!
    Any suggestions please *
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    Sep 2010
    Devon
    756
    Do you still have the original haldex ecu? If so it wouldn't hurt to switch them back over and see if that cures it. Having had a few haldex issues in the past I would say its unlikely thats your cause though, I've had a pre charge pump and ecu die at seperate times and all I had was a lack of AWD and serious torque steer lol No lights or any other symptoms. Sounds stupid but are your brake pad sensors intact?
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You are going into the relevant sections in VCDS and not just engine fault codes?
    quattrokid's Avatar
    Jan 2006
    220
    the master tech who serviced it, im sure he knows what to look for, i assume the pad sensors are intact, he went over the car with a fine tooth comb, its currently got him stumped. trying another local S3 and see what readings that has in comparison to ours. No i havent got the original haldex ecu, it was changed by the last owner... at an expense of circa 600 quid !!!!
    would a pre face lift S3 have the same ecu as a 2001 model?
    what difference would it make IF the pad sensor was tits? why would the pedal feel spongey? on our last S3 we nearly went out the window because the brake pedal was sooo sensitive !! this one is about half way down before it starts doing any braking !!
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    beachbuggy's Avatar
    Surrey
    1,746
    Quote Originally Posted by quattrokid View Post
    Faulty maf sensor can throw light
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,083
    Visit 16Klappe's Instagram Channel
    Check the fuses on top of the battery, check for corrosion and blown fuses.
    Pull each one out once at a time, wipe the spades in a rag and put them back in.
    I quite often say I'm going to do things.
    Then never do them.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by beachbuggy View Post
    Thats what I was thinking...
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    quattrokid's Avatar
    Jan 2006
    220
    the MAF sensor? i thought that measured the air temperature and density of the air coming into the engine, IF that was tits then i would have thought it wouldnt run smoothly as the air / fuel mixture would be all over the place, not sure how that would effect the abs and traction control warning lights... BUT i'd be delighted to be enlightened
    wouldnt a dodgey MAF bring up a fault code?
    cheers for your input gents....
    WR quattro
    B5 RS4
    100 S4 SALOON AUTO
    S3
    Jun 2011
    Great Melton Norfolk
    1,356
    Maf would not bring up traction control and ABS lights.
    Can you turn the traction control (esp) button off?
    Is it chewing front tyres up on the inside?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by gen.heinz guderian View Post
    Yeah it does....
    unplug you maf then turn on the engine
    Word!!!
    patTTpoa's Avatar
    Oct 2011
    Devon
    793
    Quote Originally Posted by Paradox1 View Post
    Yeah it does....
    I'll second that!!
    Pat
    Paradox1 likes this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    the ECU needs to know the engine load to be able to use ESP correctly... if its blind to load (airflow from the MAF) then it can't control actual load (through the throttle plate)... if MAF is faulty/disconnected, ESP light comes on..
    What are you scanning it with? if there are lights on the dash there WILL be a fault code in either the ABS, AWD or Engine modules...
    <tuffty/>
    Jun 2011
    1,356
    learn something new every day.
    I drive a Mercedes what do I know.lol
  1. What has happened to the front conversion stickys threads ?
    By Digzz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2012, 08:24
  2. what will happen to the ring :( ( IS THE NURBURGRING ABOUT TO GO BANKRUPT?)
    By camerontarver in forum General Automotive Chat
    Last Post: 21st July 2012, 11:50
  3. What Audi did to facelift the B5....
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th April 2004, 01:29
  4. What does a nubie to the S3's need to know?
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2004, 18:12
  5. WHAT DO YOU THINK OF THE FOCUS RS
    By MOSSY in forum Other Brands & Models
    Last Post: 20th October 2003, 17:50
