JMB RetrofitsBadger5
Results 1 to 13 of 13
    Jun 2012
    Southern Ireland
    16
    Ajq problems need help
    Hey all iv a 99 a3 1.8t quattro 180 Whitch I'm having a few issues with. Iv had her since last April and all was well till 2 weeks ago when I started getting a random misfire so assumed coil pack as iv had something similar on my a4 b5 quattro swapped them round but miss stayed the same then a few days later started loosing boost so checked for leaks and can't find any, bypassed the n249 just to simplify things no change it will run fine and boost to .8 bar then miss and only boost to .4 bar .so far iv changed the fuel filter and replaced a few pipes that looked a bit dodgy but didn't seem to be leaking checked plugs and coil packs unplugged the maf and it got worse so don't think it's that dump valves seems ok too so if anyone has any other suggestions I'd be glad to hear them
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Have you scanned for fault codes?
    What coil packs did you use? yours has the bolt down ones? if they are the beru make then they are generally rubbish... have seen a set of 4 new ones fail out the box... if hitachi then 'should' be ok...
    Scanning for fault codes will help as misfires are recorded as a rule...
    <tuffty/>
    Jun 2012
    Southern Ireland
    16
    Coil packs are hitachi bolt down got my brother to scan it last week and was showing overboosting ill get him down during the week to scan it again to get the codes
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Overboosting could be the cause of the misfire... what gaps are the plugs? is the car mapped?
    <tuffty/>
    Jun 2012
    Southern Ireland
    16
    I'm running ngk iridium with a .8 gap on a standard map ,would like to map it but rolling roads are few and far between here in Ireland
    Jun 2012
    Southern Ireland
    16
    Also have a dodgy fuel gauge since it started too drops to nothing and fuel light came on reset it and its fine for a while seems to go when the boost goes low not sure if its related
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Use a 0.7mm gap on the plugs...
    Other issue could be a bad earth... checks earths under battery tray and the one on the cam cover... if the cam cover one is non functional this can cause misfires too...
    Fuel gauge sounds like the fuel sender
    <tuffty/>
    Jun 2012
    Southern Ireland
    16
    Will check them later and let you know that could be causing all my issues
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    odd that a missfire would not show up on the scan and tell you what cylinder
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Jun 2012
    Southern Ireland
    16
    No mention of misfire when it was scanned just boost issues
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Post exact codes up, that will help... also check codes here...
    Category:Fault Codes - Ross-Tech Wiki
    <tuffty/>
    Jun 2012
    Southern Ireland
    16
    Ill list them in the next few days as iv no diagnostic gear. ill get my brother to bring his portable one down at the weekend
    Jun 2012
    Southern Ireland
    16
    Quick update solved it i think. Thermostat stuck open + cracked wires on injector loom + me driving through big puddles fast + 2 leaky injector seals and a filthy n75 .now all I have to do is fix the fuel gauge and the back spring I broke last week will take picks when I'm doing the fuel gauge and post it incase anyone else want to see how to get it out the tank.
    just goes to show the old ones were built better .my old 95 a4 b5 quattro which i had for 7 years and 240,000 miles and only put a turbo,dv,ignition amp and thermostat in all that time and abuse . Iv had my 99 a3 tqs Exactly 1year and she's cost me more allready
    thanks for the help
  1. Have a Problem & Need help!!!
    By steve123a in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2009, 06:56
  2. VAGCOM problem need help
    By 1mran in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th March 2008, 14:24
  3. Couplw of problems need help
    By bonerp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2007, 10:00
  4. Problem - Need Help please
    By Herby1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2007, 11:48
  5. BIG PROBLEM,NEED HELP FELLAS
    By imported_RELOADED99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2005, 19:18
