Monster MotorsportChris Nott
    Oct 2003
    23
    Low rev tinkling sound...
    As per title, circa 2-3000rpm I hear a tinkling sound like a bell, any ideas where this is coming from?? I am hoping its the heat sheilding (no idea where though) not hoping its a problem with the turbo.
    (The noise is more evident with the windows up rather than down)
    00' 210bhp S3 btw. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Oct 2005
    wales
    50
    Re: Low rev tinkling sound...
    sounds more like heat shield as you'd hear the turbo more with windows down, also tinkling doesn't sound like turbo, is it more a metallic clicking or ringing?
    Timbo's Avatar
    Slowest car ever round the Top Gear track?!?
    Dec 2004
    Surrey
    275
    My old car had a metallic rattle at certain revs which turned out to be the cat breaking up.
    imported_VaulterTim
    Sounds exactly like the problem described hear in this thread...
    Vibration
    I could be wrong but I think it's the wastegate.
    T
    Aug 2003
    Surrey
    469
    Heat shield does make a tink tink noise when hot. Usually hear it on cars that are cooling down more than heating up though? From what I remember, sounds someone lightly tapping a teaspoon in the bottom of a cup of tea!
    Oct 2003
    23
    Thanks Tim, read that set of posts and still not sure its as described, the noise on mine only comes in as you accelerate, not as you lift off the gas, it also seems to pass after the engine gets to temp'
    I had a look at the weekend and the exhaust seems fine. Is the turbo mounted behind the main heat sheild??
