AH FabricationsEM Tuning
Results 1 to 8 of 8
    Mar 2013
    Cambridge
    42
    Stuttering on idle and under power
    Morning all,
    Just had a terrible drive into work in my S3. The past couple of weeks the idle when cold has been very poor and I've had to apply a little throttle to keep it from cutting out. This morning the car started fine but under power it would stutter. I had a similar issue to this once before and it boiled down to the MAF.
    Does anyone have any suggestions?
    Will
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    you will need to get it scanned really but I had the same with a maf. get it scanned first then you'll know which route to take
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Mar 2013
    Cambridge
    42
    A friend has a reader so I'll plug that in and see what it brings up.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    If it drives "ok" with light throttle I would suggest map sensor or more likely failing coil packs.
    I quite often say I'm going to do things.
    Then never do them.
    Mar 2013
    Cambridge
    42
    There is still some stuttering when driving on a constant throttle. Is there a way to see if the coil packs are going or just a case of replacing them and hoping that sorts it?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    pull the out one by one
    also try disconnecting the maf
    Word!!!
    Mar 2013
    Cambridge
    42
    I just about got home, the car went into limp home mode! Turned out coil 2 had failed. £20 later and I'm back up and running and back on full power.
    Cheers for the help guys.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    Good stuff
    Word!!!
  1. FSi-Lumpy idling and starting problems
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 16:00
  2. A3 1.8T sport - bad idle and stalling issue
    By MrCoont in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2006, 11:13
  3. Hunting idle and poor fuel consumption
    By gillbe in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2005, 13:59
  4. for those with DSG and Tdi power
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2005, 08:26
  5. CD Changer Cable, and boot power
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th February 2005, 07:38
