Chris NottVolks Autos
Results 1 to 27 of 27
    Dec 2011
    630
    Hesitation after gear change after fmic getting fitted
    Got my fmic fitted tonight finally but on the drive after fitting I noticed their is a hesitation/lag after a gear change I can't remember it being their before.is this normal ? Could this be due to the increased volume of the intercooler ?
    lovemelongtime's Avatar
    Jun 2012
    Horsham
    335
    Could be a boost leak? Have you scanned for codes?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Airleak would get my vote... what clamps did you use?
    <tuffty/>
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    You want decent hoses like from mr silicone of ebay for example. Stainless jcs clamps and alloy pipes with beaded ends.
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Also what size pipes and intercooler are you using? I got a tiny bit of lag but it was more like a surge or torque lol
    hardly notice it after a while
    Word!!!
    Dec 2011
    630
    Quote Originally Posted by lovemelongtime View Post
    not yet will give it a scan later today I only have vcds lite
    <tuffty/>
    it was jcs hi grip clips mate and they all had a good tight nip up
    Quote Originally Posted by Paradox1 View Post
    that's what I have
    63 mm pipes mate and it is a ah v2 cooler,that's what I'm getting,it like if I giving the car some and go up the gears I change gear and foot to the floor again then less than second later I get a surge of torque
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Thats a good thing! I dotn know if its the fact ive got used to it, or the ECU has made changes but now it feel like I get the extra torque without the lag. Go for a long drive and see if the thottle response changes.
    Word!!!
    Dec 2011
    630
    sound mate I will do,should I maybe undo the battery for a bit first ?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Erm you can do if you like, leave it disconnected for about half hour then connect it and let it idle for about 5-10 before you drive it..
    or
    you can just go for a blast and it will learn it that way... I prefer the latter
    Word!!!
    Dec 2011
    630
    or
    the latter ,how long should it take to sort it's self out if its the ecu
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Depends on your petrol tank lol
    Not sure on a time limit but i know the ECU learns everytime you drive
    Word!!!
    Dec 2011
    630
    just done a 1/4 of a tank with mixed driving on B road and bypass,it's made no difference when after changing gear it's as if I have lifted totally of the throttle then went to the floor again ?? getting really annoyed with the car now
    Dec 2011
    630
    Scanned with vcds lite unregisterd and got no codes
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I cant imagine it beeing that bad unless it has a leak somewhere mate. Mine felt like it had a little lag but it was much quicker than before.
    I fitted this connected up to my k03s so im guessing yours is a k04 and should be as bad? honeslty sounds like a leak somewhere though
    Word!!!
    Dec 2011
    630
    though
    mine is a k26 mate? Every clip was nipped up really tight and if its leaking it bumper back off ,could it be the mtm map needs changed because the cooler is fitted ?
    will take it another drive later incase I've not gave it enough time
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    a remap with smoothing out the power delivery. Id advise going for a custom map tbh. I fmic always works better once its been mapped as it take all the bolt on's into account. Where would you get it mapped.
    Im not sure how big the MTM k26 turbo is. isnt that from a porsche? Im not sure how much bigger it is compaired to a k04.
    What was the lag like before the intercooler? like when did it start spooling and hit fully boost?
    Word!!!
    Dec 2011
    630
    The only thing that's put me off going custom is my rods ain't been done,I am sure it is from a Porsche mate,I don't know how it compares size wise to a ko4
    it would spoil from between 3/3.5 k and be well on its way for 4k rpm,the turbo still comes on song at the same time it's just after a gear change,it's as if I have lifted of then went again surely it wouldn't be taking that time to build up pressure again after dumping ??
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    got to remember its got the lag from the turbo + the massive volume of space in ther intercooler to fill if you know what I mean.
    You dont have to get a full blown, all out agressive map. you could always get a map with low tq figures to keep things safe?What figures are you running at the moment?
    Word!!!
    Dec 2011
    630
    but there should be no lag changing from 3rd at the redline into 4th as its still staying high in the rev range is my thinking right ?,I understand about filling the intercooler it's self does any one know the standard volume compared to the volume of the fmic ?
    Yeah I suppose I could do that mate,well on the dyno print from qst it says 328bhp and 467nm of torque but that's from who did the work so possible dyno lottery but the car is pretty quick
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    tbh i wouldnt do any more mods until rods are fitted.
    Welly bent rods on a stage 1 map after fitting a fmic (not to scare you) but these engines are getting older and things need replacing. Just change the rods then you an do all the mods you want within reason and know the engine wont go Kah-boom!
    Word!!!
    Dec 2011
    630
    Thanks for that no sleep for me tonight haha,I've read about rods going but was told its all in the mapping as some maps have huge torque spikes the mtm map I have is very progressive that's why I've been wary of a different map,I do need to get the rods done but nowhere in scotland with a decent rep will do them well that I know of
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    may be worth going to a reputable place for them. Im sure there is loads of vag specialist that will do it for you. but i gues it all comes down to cose, yuo can get the install kit for around 500-600
    then maybe about 4-5 labour, just do it in stages
    Word!!!
    Dec 2011
    630
    i will look into more in depth And see who is close by to get them done,with rods done is the engine good enough for 400bhp ?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I think so yeah.
    last time I saw welly's car ar castle combe, it was running 450 on the stock head, just rods lol
    Word!!!
    Dec 2011
    630
    I think so yeah.
    A 450 s3 must be awesome
    Dec 2011
    630
    well took the car out again and leathered the arse right of it and its alot better now just a ever so slight lag but that's surly just the time it's taking to pressurise the cooler
  28. #27
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Yeah I wouldnt worry about it mate
    Word!!!
  1. 2.0tdi 140 Loss of power after gear change?? any ideas?
    By DCW87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2013, 15:56
  2. Acceleration hesitation between gear changes
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2012, 20:55
  3. Hesitation after gear change
    By waring192 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2010, 22:42
  4. Coding change after fitting HID's?
    By mattpanton in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2010, 18:26
  5. Revving itself after gear change :S
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2010, 16:48
