AH FabricationsVolks Autos
Results 1 to 10 of 10
    Jul 2011
    Very north of England
    42
    Renewing rear brake pads. What size spanners? Do you have to remove console?
    Hi
    I have to replace rear brake pads and it seems straight forward except for a few things. Haynes says you have to release the handbrake and therefore remove centre console, do you really have to do this? Apart from that it seems okay, but I only have a 15mm brake pipe spanner which seems rather thick. Online suggests you need a thin 15mm to hold guide pins still and 13mm to remove guide pin bolts. Also I only have a pair of circlip pliers to adjust caliper, I hope this hayne hint works.
    Regards
    Taff
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    I think youll find when they say release the hand brake they mean just that i.e. not have the handbrake lever in the up positon as opposed to disconnecting the hand brake, I've recently done my S3 rear brakes and used variety of spanners, allen keys and large lump hammer to get the disks off the hub
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Jul 2011
    42
    Cheers sportquattro going to give it a go now.
    Taff
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    You don't need to touch the handbrake cable to replace rear pads...
    Just undo the two 13mm bolts holding the caliper to the carrier (leave the carrier attached to the beam), wind the pistin in using a suitable tool and plonk the pads on the carrier... replace the caliper, use new bolts (normally supplied with the pads) and job done..
    <tuffty/>
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    <tuffty/>
    open the brake fluid tank when winding the pistons back!!
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Jul 2011
    42
    Cheers, have car up on axle stand but didn't get caliper tool. I thought I'd try haynes tip with circlip pliers. Doesn't work. Now I have to wait for the wife to get home so I can nip down to halfords to get a £35 tool. So much for saving money! And probably lose a whole days leave!
    Taff
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I got my caliper piston tool off ebay for about 15 quid. bit too late now but you know lol. or you could borrow one from a mate....
    Word!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Yeah... seems the later VAG calipers don't like the pliers trick of winding in the piston... was sat on my arse for 30mins trying on my S3 before I borrowed the tool from Bill and it took less than a minute...
    <tuffty/>
    Jul 2011
    42
    Cheers, got tool last night, woke up this morning and it is pissing down! Will have to leave it until weather gets better. Could have got one off ebay. Will have to use the wife's car for work.
    Oh well.
    Jul 2011
    42
    All finished. o/s caliper extremely hard to get back in almost out all the way it was a real struggle to actually get the tool to fit in. n/s no problem at all took minutes.
    Cheers all
  1. Rear brake pads
    By SDO in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd August 2008, 22:40
  2. Rear Brake Pads & Caliper Tool ???
    By roy_barber99 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2008, 21:35
  3. Rear Brake Pads - which brand
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2008, 09:14
  4. Rear brake pad change...
    By oversteer in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2007, 14:21
  5. Changing rear brake pads (A4 Avant)
    By NickB in forum General Technical / How To
    Last Post: 4th November 2006, 16:38
