Hi
I have to replace rear brake pads and it seems straight forward except for a few things. Haynes says you have to release the handbrake and therefore remove centre console, do you really have to do this? Apart from that it seems okay, but I only have a 15mm brake pipe spanner which seems rather thick. Online suggests you need a thin 15mm to hold guide pins still and 13mm to remove guide pin bolts. Also I only have a pair of circlip pliers to adjust caliper, I hope this hayne hint works.
Regards
Taff
Regards
Taff
