Chris NottBadger5
Results 1 to 14 of 14
    May 2011
    stocton-on-tees
    64
    Help in getting my IMMO-ID code
    As title can eney one help me I would like to program a second key saw I have a spare. The problem I have is that when I got the car remap do they said that my ecu was from a A4. My car is a A3 1.8t just not shower if that will be a problem as the car had two different key one for the doors one for the ignition I've changed all the lock to one key keeping the original key fob it still starts and runs no problems just I would like to have a spare key just in case the key gets damaged/ lost
    any help will be nice
    thanks Karl
    May 2011
    stocton-on-tees
    64
    Any help would be helpful
    May 2012
    RETFORD, NOTTS
    1,753
    Sorry you are too far away, maybe a local auto locksmith could supply you a new key?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    May 2011
    stocton-on-tees
    64
    I don't need new key just reprogram the spare one but thanks any way
    Mar 2010
    Durham NE
    578
    you will need the skc code from the current clocks you have in and then you can programme the keys in.
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    You need software called Vagtacho to extract the SKC code
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    May 2011
    stocton-on-tees
    64
    Ok thanks for that the next question is where do it get vagtacho from can I get it of eBay
    May 2012
    RETFORD, NOTTS
    1,753
    Try hickleys, £499 plus vat iirc.
    Mar 2013
    65
    Hi i ordered a vag tacho cable about a week ago so should be here soon your welcome to come use it i only live in sunderland
    H122 Vagtacho USB Version V 5.0 VAG Tacho For NEC MCU 24C32 or 24C64 for VAG Car | eBay
    Regards
    May 2011
    stocton-on-tees
    64
    Thanks for the offer Kodak but I've orded one from amazon last night and will have it for Monday. It only cost £17 it will work or not but for £17 not the asst but will have a go
    Mar 2013
    65
    Quote Originally Posted by renton View Post
    no problem mine is here now if you get stuck
    May 2011
    stocton-on-tees
    64
    Thanks again my is here to if I get stuck ill give u a shout
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    498
    Let me know if this works as I have a new instrument cluster I need to reprogram and need to access the pins.
    AMD stage 2 map, BBS LM 19s, 20mm Momo Spacers, Black Diamond Discs, Ferrodo ds2500 pads, Milltek Exhaust, Pipewerx downpipe and Decat, Custom FMIC, 4 bar Fuel Pressure Regulator, Forge 007p, Forge short shift, Forge DV relocation ,Forge TIP, S2000 Filter, Sachs Race Clutch, Sachs Light weight Single mass flywheel, ForgeOil catch tank, De baffled Charge pipe & Polished, Polished Inlet Manifold, N249 Delete, PCV Delete, Red Engine Mounts, Forge Boost hoses, Angel Eye Headlights, LCR Splitter,
    Mar 2013
    65
    i was able to add keys scan id48 transponder chips and change mileage also gave me the immo code too excellent product
  1. immo coding
    By raz83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2013, 19:20
  2. Decipher Vehicle Data codes
    By wigginer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2003, 12:05
  3. SILVER A3 PAINT CODE
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 17:28
  4. A4 KEY CODE PROBLEM
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2003, 18:13
