Volks AutosAH Fabrications
    Mar 2013
    Soham, cambs
    12
    Cam pulley problems
    Hi,
    was just wondering if anyone else has had problems with the cast woodruff key snapping on there cam pulley? have just put an ARZ head onto my AJQ engine and the timing marks were out (bottom end lined up but cams were out,they would have snapped on pistons when we tightened up head), so we duly took off the old pulley to find the key had snapped, hence why the valves had struck the pistons. the new (second hand head) was the same, was broken also but had not slipped round far enough to damage valves as they were all fine with no marks to indicate otherwise. I have a new pulley coming monday so should be up and running then (piston damage was minimal so will be fine).
    The old head, when we stripped the cams off, had had a sludge problem(oil pressure, pickup pipe blocked) and the exhaust cam had run dry and had worn into the head so pressume this caused the key to break but if anyone else has suffered the same then let me know and what caused it?
    will post pics of old and new when daylight arrives
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    This normally happens when some one turns the engine over using the cam pulley bolt... bolt should be torqued to 65nm when refitted
    <tuffty/>
    Mar 2013
    Soham, cambs
    12
    Cheers tuffty, well the new one was my fault then as used the bolt to turn to timing mark when head was off, 30 quid lesson there. will just use the pulley from now on!
    engine only has to last till i can rebuild old ajq with forged pistons so i can uprate bhp,
    will post pics of old cam and damage it did to head.
    thanks
    BENJAMIN's Avatar
    Mar 2011
    459
    Also happens when people use an impact gun to tighten the pulley.
    2008 8P S3- Black edition. 'all the options....'
    Mar 2013
    Soham, cambs
    12
    would like to think people that did that got what they deserved! haynes manual and my next door neighbours tools and wisdom saved me on this one, pulley i can replace with no real issues and it was a good learning curve for me as it was my first dohc head to change.
    for the handsome price of £860 i now have an 1999 1.8t quattro 180 bhp on the road (tuesday if bits arrive) taxed for a month and mot'd for 6!
    looking on here and on you tube its gonna turn into at least a 350bhp monster by the end of the year!
    plus a big thanks to barry who gave me a shelf bracket to cut up and use to block the egr on the azr head, try saying that quick after a few drinks!
  1. Possible alternator pulley problem?
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th January 2012, 19:19
  2. 1.8t 20v cam pulley
    By tony696 in forum For Sale/Wanted - Audi Parts
    Last Post: 3rd January 2012, 13:58
  3. Cam fitting problem 2.5 v6 tdi ake
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2010, 10:31
  4. Cam pulley wobble!!!!
    By btmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2009, 19:30
  5. Cam Sensor problem?
    By ceefna in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2008, 16:21
