AH FabricationsChris Nott
Results 1 to 10 of 10
Thread: Engine rebuild
    Sep 2009
    Isle of wight
    207
    Engine rebuild
    Any ideas how much would you expect to pay for an engine rebuild, rods,shells,rings,bores homed,head skimmed and rebuilt
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    887
    Add Vex182 on Facebook
    What engine? And what parts? OEM or aftermarket?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Sep 2009
    Isle of wight
    207
    Sorry s3 Apy, aftermarket parts
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Have a look in the sponsors section and pm the relevant ones for a quote Tony.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    depends largely on the spec... most builds I have seen tend to hit 2k +
    rods and pistons alone will set you back a grand... then there is all the gaskets which can run to 200 ish... rebore is 200 ish, block decking is only needed if in a bad condition as a rule..
    Normally a good idea to replace stuff like oil pump, crank seals, oil pump chain an tensioner, new big end and main bearings plus new mains bolts.. I could go on...
    <tuffty/>
    Sep 2009
    Isle of wight
    207
    Thanks for the info, the problem is living on the Isle of Wight people can charge what they want, and half the time don't do a good job
    Sep 2010
    Devon
    756
    Theres a guy on vagtalk selling a decent rod kit ( rd rods, rings, various gaskets etc ) for about 550, good value and good products, easy to get your pants pulled down so buy sensibly and get an experienced garage to fit. Doesn't have to cost the earth mate or I wouldn't be doing it lol
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Sep 2009
    Isle of wight
    207
    Thanks for all the info peps, is vagtalk on facebook slowcoach3 ?
    Sep 2010
    Devon
    756
    yes mate
    Sep 2009
    Isle of wight
    207
    Just looked and can't find it slowcoach3
  1. Engine rebuild?
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2008, 00:04
  2. Engine rebuild options???
    By dappadan786 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2008, 22:27
  3. New and need help - any contacts for an S4 engine rebuild
    By grgh in forum The Welcome Section
    Last Post: 14th March 2008, 19:30
  4. S3 ENGINE REBUILD!!
    By pault in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2007, 09:31
  5. engine rebuild?
    By SQ_lover in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2005, 01:43
