Volks AutosSky Insurance
    Oct 2011
    greater mcr
    114
    engine swap amk to bam engine, s3 8l
    Morning all
    Im in the process of swapping my 2002 amk S3 engine which has snapped a rod and put a hole in the block. (vvt wideband engine so im told ?)
    What I need to know is will a late 06 I think low mileage bam leon c r complete engine Plumb straight in and work off my original amk ecu ? Ecu has a cus code stage1 map.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Yes it should be the same, what i would do if it was me, is use the bare BAM engine but bolt all your sensors and manifolds to it, that way if they changed anything over the years it wont mess you about
    ​Wish Rachel would let me have my TDI mk5 back
    Oct 2011
    greater mcr
    114
    Yea I'll swap the sensors over as I know mine worked, just not 100% on the ecu and running side of things
  1. APX VS BAM engines..
    By Shy19s in forum TT/TT-S/TT-RS Forum
    Last Post: 24th November 2009, 10:10
  2. Where to get a Pre Cat Lambda Sensor from for best price? BAM Engine
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2009, 22:43
  3. APX vs BAM engine..
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2009, 09:38
  4. Hardpipe kit for BAM engine..
    Last Post: 5th May 2009, 20:22
  5. APY and BAM engine codes
    By Dubplate in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2008, 21:39
